Volvo VNL 2006 cummins 15 error code 285
Discussion in 'Trucks [ Eighteen Wheelers ]' started by sogd, Dec 15, 2011.
  1. sogd
    sogd Bobtail Member
    Tambov
    285 SAE J1939 Multiplexing PGN Timeout Error - Abnormal Update Rate
    Engine work only in idle. Accel pedal dont wor.
    I search computer data lines wiring diagram.
    Thanks
  3. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    J1939 CAN wont working.
    Start with checking gor resistance. Turn ign off and check C-D resistance. Must be 60 Ohm. Check both the pins for short to ground. Check CAN wiring from MCFC connector.
    Pay attention that any control unit may involve CAN in fault
  4. sogd
    sogd Bobtail Member
    Tambov
    Thanx! I check it
  5. sogd
    sogd Bobtail Member
    Tambov
    Solved. Open circuit power feed to VECU.
    Pablo-UA, Thanx!!!
