Volvo Too Much Maintenance To Own?
Discussion in 'Volvo Forum' started by csmith1281, Nov 22, 2017.
  1. csmith1281
    csmith1281 Medium Load Member
    446
    266
    May 29, 2017
    Atlanta, GA
    I've read on here a lot of guys saying do not buy Volvos because the proprietary engine is too hard to service and find parts for and it's too expensive. Anybody on here want to tell me about their experience owning and/or operating Volvos?
  3. CoyoteExpress
    CoyoteExpress Medium Load Member
    367
    173
    Oct 29, 2014
    Carlingford NB Canada
    Close 1.6milkm / 1mil miles
    2times cups
    1 set injectors at 1.55mkm
    Some nox sensors
    Alone the biiiig +on savety is a reason to buy them.
    Learn to know the fault codes and know with you can ignore
    Nox ... venturi pipe sensors .. lots of times send a code ... 24h later code gone ... dirt on sensor on nox maybe take out and spry with carbon cleaner ... saves 1000$
    csmith1281 Thanks this.
  4. csmith1281
    446
    266
    May 29, 2017
    Atlanta, GA
    What would you say about it being harder to find service and parts for the proprietary engine?
  5. rogueunh
    rogueunh Road Train Member
    1,082
    22,200
    Jan 4, 2011
    There's a heck of a lot of Volvo and Mack trucks on the road. Their engines aren't a secret.
    CoyoteExpress and d281833 Thank this.
  6. csmith1281
    446
    266
    May 29, 2017
    Atlanta, GA
    Maybe not a secret… But not able to be serviced at every truck stop either? Is that what some people are complaining about?
  7. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    '01 with a Cummins N14, 1.8mm no inframe. Very quiet and smooth riding truck.
    Doesn't need any more maintenance than any other truck, pre-emissions that is.
    @boneebone
  8. rogueunh
    1,082
    22,200
    Jan 4, 2011
    I would never let a truck stop touch any of my trucks. But I do have a new Mack and my local independent truck repair garage has serviced it with no problem. It has the MP8 which I've been told is identical to Volvo's 13 liter engine, just some parameter differences.
    csmith1281 and d281833 Thank this.
  9. csmith1281
    446
    266
    May 29, 2017
    Atlanta, GA
    Is the local garage factory certified?
  10. Sharky88
    Sharky88 Heavy Load Member
    715
    851
    Sep 25, 2013
    Getting a Volvo serviced is not a problem a standard pm is no different then any other engine. For repairs usually you will have to find a dealer. There are some local shops that do work on volvos and are very good. Mine is a newer motor and is still under warranty so any work that n dis done is done at the dealer. I haven't had too much trouble getting in a dealer shop although I have herd of people waiting a couple of days. That being said I have also herd of that with other manufacturers
  11. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    ive serviced volvo for years am not factory certified but will tell you i have fixed a ton of problems dealer couldn't find, if you are looking for a truck to be able to fix in a truck stop than none of the new trucks will work for you everything has got very complicated since def was introduced, you will have more problems finding a place to service a dd15 or paccar than you will have volvo, as for parts they go up and down, a lot of electrical but also same in all other trucks nowdays everything is complicated. Unless you look into a pre emission truck so 03 and under everything else get complicated. in my opinion you will not find a safer, easier to drive and also comfortable unless you look at a volvo but the rest is up to you to decide.
    bewhite90, Volvo8873, disoba and 7 others Thank this.
