Volvo T.V. Mount wrong size for my TV
Discussion in 'Questions From New Drivers' started by BigSexy53, Jul 16, 2017.
  1. BigSexy53
    BigSexy53 Bobtail Member
    35
    11
    Apr 11, 2017
    I am in need of help with mounting my 32 inch TV in my Volvo 780. It has the bracket, but the 4 holes in the back of my TV are too wide. A lady needs help in finding out what to do, what extra stuff to buy and where. I tried fuel stops but no one could put it up for me. I thank you kind gentlemen in advance. Its a Sanyo TV.
  3. Patronas01
    Patronas01 Light Load Member
    132
    79
    Dec 23, 2014
    California
    The best way to do it: go to any home improvement center buy a 48" long aluminum blade, cut two pieces so they will cover the mounting wholes of your TV, (placed horizontally) drill 4 wholes on each blade, (2 for the TV bracket and 2 for the TV). you will need to measure the distance of the wholes at the TV bracket and TV. then buy the screws to mount the blades on the TV bracket, and the TV.
    I know it may sound complicated but it's an easy project for anybody with some Do It Yourself skills. You will need a metal saw blade, a drill with metal drill bits, screw drivers, and pliers.
    Hope that helps.
  4. JR OTR
    JR OTR Light Load Member
    272
    198
    Jan 13, 2009
    The problem you have is that the VESA holes on your TV and the mount are different size. Simply google "vesa tv mount adapter" and pick something that has the sizes you need and get it drop shipped from Amazon for 10-15 bucks. Problem solved.
    fargonaz Thanks this.
  5. Sharky88
    Sharky88 Heavy Load Member
    715
    851
    Sep 25, 2013
    when i bought mine it had an adapter that came with the truck to fit different tv's
