Volvo SPN 3226 FMI 12 (Bad NOx Sensor)
Discussion in 'Trucks [ Eighteen Wheelers ]' started by tallmon, Mar 4, 2016.
  1. tallmon
    tallmon Medium Load Member
    657
    319
    Oct 22, 2014
    2011 Volvo with a Volvo D13 Engine VIN 4V4NC9EJ6BN297675
    Getting error: Aftertreatment 1 Outlet NOx
    Engine #1
    Out Of Calibration
    Bad Intelligent Device Or Component
    SPN 3226 FMI 12 and FMI 13
    Is it shorted or unplugged?
    Detailed picture of where it is?
    thanks.
  3. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    Mounted on passenger frame rail with 8" wire that leads to sensor end that threads into scr catalyst. It is about 1/2 way back roughly under where passenger seat is. Type it into ebay to see what it looks like. 2 10mm bolts hold it to frame. 1 1/16" wrench (I think) to unscrew sensor end from can. Pretty expensive from dealer. Cheap on ebay.
  4. tallmon
    657
    319
    Oct 22, 2014
    Thanks. Can that just be replaced? Does it have to be calibrated with VCAD? If it just starting popping up, how long before derate?
  5. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    Does not have to be calibrated. Do not wait too long because truck will not regen if sensor is not working properly. After changing, do a regen.
  6. tallmon
    657
    319
    Oct 22, 2014
    So the dealer replaced both nox sensors and they are getting high readings and said the the cylinders are unbalanced and what to keep diagnosing. Attached is the test. Should I keep diagnosing? Is this serious??
    I couldn't attach but here are the test readings
    -1 - 9 11 - 20 6 14
  7. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    It is very common, and you should replace the sensors in pairs (inlet and outlet) at the same time. Problem is, as you found out, they are very expensive sensors. I hope that you kept the old inlet sensor as a spare. I think that your readings are not serious, but maybe Nasriza will chime in. He is really good with Volvo's. I am O.K.
  8. tallmon
    657
    319
    Oct 22, 2014
    So, they replaced both sensors. Both were bad. After regen had super-high nox readings. No codes. After further diagnosis they found a bad DEF doser valve. Valve replaced, engine good as new.
  9. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
  10. Kennyuscg
    Kennyuscg Bobtail Member
    Oct 31, 2016
    When you had this problem, what was happening to your truck aside from not doing its regen? Does it affect engine performance?
    I've had my 2012 for almost a year now and I'm getting an error for the NOX outlet sensor for about 10 months and it seems like it's doing its regen and I've been refueling DEF. The truck runs good.
    The_Truckr Thanks this.
