Volvo I-Shift gear shift/slipping problem
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by korex_UA, Sep 13, 2019.
  1. korex_UA
    korex_UA Bobtail Member
    46
    Apr 7, 2007
    Here is what is going on. D13 with I-shift 560K miles.
    When backing up uphill on Low revers (R1) truck started to jerk, like someone pushes and releases Clutch pedal, when you manually switch to R2 (high) everything back to normal.
    Checked for Oil leaks, air supply etc.. no warning signs. Truck drives forward just fine.
    couple of days later , same problem with Revers, but on a flat surface, still drives fine when on forward, including loaded and uphill, but in a few days same thing start to happening with forward gears, especially under the load uphill, so had to drop the trailer and bobtail it home, still same jerking /not shifting to the lower gears properly. Mechanic even without looking said "you need a new transmission" Any experience with something like this?
    Lpirtle Thanks this.
  3. Cattleman84
    Cattleman84 Road Train Member
    9,869
    70,289
    Nov 1, 2017
    The Sticks, Idaho
    Soumds to me like the clutch is slipping. Take it to a Volvo dealer and tell them what its doing.... I almost bet it just needs a new clutch.
  4. bryan21384
    bryan21384 Road Train Member
    14,489
    30,980
    Sep 18, 2009
    Memphis, TN
    It could be a need for a new clutch, or could be a transmission issue, maybe a spicket bearing, and that ain't a cheap repair. Get it checked out and make sure you get a second opinion
  5. ctsflatbed
    ctsflatbed Bobtail Member
    10
    4
    Sep 13, 2019
    I diagnose those all the time at work. The spigot bearing has failed. It's the bearing inside the transmission on the back of the input shaft. You can replace the spigot bearing but its expensive. Cheaper to replace the transmission with a Short. Make sure you replace the clutch and the clutch cylinder while transmission is out.
    GreenPete359 and Lpirtle Thank this.
  6. manjit1
    manjit1 Bobtail Member
    4
    Oct 9, 2019
    chicago
    i have volvo 2013 ishift getting stuck in any gear gas paddle won’t work dash shows transmission maintenance required come back normal after few seconds but my truck works fine in morning after 2-3 hours of driving it getting message again sometime very frequently. help?
  7. ctsflatbed
    10
    4
    Sep 13, 2019
    Might be something wrong with the clutch or clutch cylinder. Need to take it to a dealership to get checked.
    manjit1 Thanks this.
  8. manjit1
    4
    Oct 9, 2019
    chicago
    due to def delete i can’t take it to the dealer. i drop my truck to transmission rebuilt shop. they got faulty code input shaft sensor then they had issue with their computer yesterday. i hope they will start diagnose again today.
  9. manjit1
    4
    Oct 9, 2019
    chicago
    i went to shop today they got hundreds of several inactive faulty code but nothing active. they delete all inactive codes. finally i start test driving with mechanic and connected computer after one hour of driving road test we couldn’t find any codes, i was told by mechanic they are going to start my truck by monday morning and let it running (ideling) until afternoon to get hot whole system and then we will start driving again to see what’s going on. because my truck starts problem by afternoon not in morning.
  10. bonous
    bonous Light Load Member
    209
    69
    May 31, 2014
    Did you ever get it fixed and what was the problem?
  11. tsp1chl
    tsp1chl Bobtail Member
    11
    Nov 4, 2015
    Did you ever get it resolved?
