Volvo I-shift 12 replacement with and I-shift 13
Discussion in 'Volvo Forum' started by Diesel Power, May 10, 2019.
  1. Diesel Power
    Diesel Power Bobtail Member
    45
    16
    Nov 1, 2016
    I have 2015 Volvo ,D13 engine, I-shift 12 speed transmission , 2.64 gears. When time comes can I replace my transmission with overdrive 13 speed I-shift (its basically same as 12 speed transmission, it's just has 1st crawler gear, it was designed for construction work so it has more robust internals). If I could do that, do I need to update my engine ECM?
  3. nasriza
    nasriza Road Train Member
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    you do not really need to do that you have the low gear button on the back side of shifter either way what you are looking to do it's going to be really hard, to be able to change from i shift to manual just need to replace ecm's alone as far as vehicle ecu and abs ecu, just expensive but doable.
    KB3MMX and Diesel Power Thank this.
  4. Diesel Power
    45
    16
    Nov 1, 2016
    I was thinking to replace it with I-Shift 13speed with crawler gear, not manual 13speed.
    KB3MMX Thanks this.
  5. nasriza
    2,398
    2,074
    Feb 1, 2013
    Chicago, IL
    Try your low gear on I shift this trans gets used for a lot of logging operations in Europe so it should be more than capable of doing the job
  6. Diesel Power
    45
    16
    Nov 1, 2016
    Thanks. I will try.
  7. 05vnl670
    05vnl670 Light Load Member
    165
    60
    Feb 17, 2013
    From reading the I shift manual the L button is not a low gear selector, the button is used in emergency problems with transmission. I think its called Limp Home Mode.
    KB3MMX Thanks this.
  8. KB3MMX
    KB3MMX Road Train Member
    3,075
    2,595
    Dec 29, 2014
    Orrstown, PA
    Correct.
    first gear on a XE truck with 2.64 rear ratio has always been a problem with the Volvo Mack transmission... The crawling speed is too high with that rear end ratio for very slow maneuvering....... Leading to clutch overheat alarm going off frequently and reduced clutch life if you aren't careful how you drive it..
    860 I'm having built with turbo compound and 2.47 rear will have the crawler 13-speed severe Duty iShift transmission..... I think with that fast of a rear it will be a necessity to have a different ratio for 1st gear on normal trucks.
  9. benrab
    benrab Medium Load Member
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    Be carefull with your drive shaft.
    KB3MMX Thanks this.
  10. Jacoooooooo
    Jacoooooooo Heavy Load Member
    748
    1,054
    Oct 20, 2013
    Severve Duty iShift for on highway operation? Why would you give up 750k warranty for 100k that comes with severve duty?
    Your clutch warranty also shrinks to 100k, from standard 300k. I’d rather have warning on the dash sometimes and clutch replaced under warranty.
    Mine, 2015 780 with 2.43 rears has standard iShift. I did have warranty repair on it right before 750k.
    You really need that warranty...
    KB3MMX and Newto Trucking Thank this.
  11. KB3MMX
    3,075
    2,595
    Dec 29, 2014
    Orrstown, PA
    Wrong, if you get the 13speed(or 14) in a road tractor now it designates the X series iShift ... you still have the 60mo/750k warranty.... I went through this with the dealer on the last order
