Volvo headlights replacement, is there a decent aftermarket brand
Discussion in 'Volvo Forum' started by hoffman2538, Jan 2, 2019.
  1. hoffman2538
    hoffman2538 Bobtail Member
    8
    want to replace my foggy headlights on my 09 vnl.ive seen black looking headlights on other trucks does anyone know if volvo makes these as an option to the stock clear headlights?
    i found only aftermarket ones not sure of the quality anyone have thoughts on using aftermarket vs stock,where to get best deals,aftermarket brand, etc?
    thanks
  3. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
  4. Rob100100
    Rob100100 Light Load Member
    206
    122
    Mar 5, 2016
    I bought the Volvo Bi Xenon kit from deep space lighting. Extremely happy with it. Get the torx fitting. Makes life very easy when you need to adjust the headlights.
    Volvo Archives - Deep Space Lighting
  5. Mudman78
    Mudman78 Light Load Member
    106
    108
    May 23, 2016
    The problem is heat burns the chrome off the reflector dish and it will no longer disperse the light. The dish is not available separately. A whole headlight assy. is $400+. Our Volvo dealer used to offer aftermarket replacements and LED replacements. Both Chinese. There were so many problems with them as well as no warranty support, so they stopped selling them. I replace them with OEM every 4-5 years at $800+ per truck.
  6. d281833
    d281833 Heavy Load Member
    881
    919
    May 15, 2012
    I just cleaned up the lenses. A kit, hour of my time and good to go.
  7. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    just go with eagle eye headlights led they are reasonably priced and quality is ok not the best but not the worst. light up pretty good and around chicago or online you should be able to get them for about $700 for the set volvo is usually around $1200 for aftermarket and 1800 for original.
  8. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    Volvo Factory LED headlights are black background and very much worth the expense.
    No junk aftermarket headlights and no chasing or changing bulbs like halogen junk or retrofits.
    If you don't mind pi$$ing around constantly, get some aftertermarket lights, otherwise... oem is install and forget. Much better.
  9. Mudman78
    106
    108
    May 23, 2016
    What's the part number for the Volvo factory LED's?
  10. Medysa79
    Medysa79 Bobtail Member
    6
    Personally I put LED lenses into old casing. A bit of cutting to fit lenses and a good polishing makes me happy. Lenses cost me $280. HID won't last you to long because of vibrations.
  11. disoba
    disoba Light Load Member
    53
    59
    May 7, 2013
    I purchased a cheap Chinese set for $270 on E-bay and they are garbage, very poor lighting and getting worst. almost useless.
    My sugestion, get the original at a Volvo dealer.
