Volvo Dash Cluster issue
Discussion in 'Volvo Forum' started by AlexD13, Feb 20, 2021.
  1. AlexD13
    AlexD13 Light Load Member
    298
    85
    Jun 13, 2016
    Hi everyone, i removed my dash to replace the buzzer/speaker. Upon hooking it back, my lights are all gone from the dash. Any ideas?
  3. 6cuda6
    6cuda6 Light Load Member
    259
    176
    Oct 9, 2020
    Sounds like you may have accidently touched something in the cluster when replacing the piezo [noise maker] ....i am assuming you checked all dash connectors, fuses and have battery power of course. The only trick here would be to try a known good cluster to see if it powers up properly or take things back apart to make sure nothing is loose, damaged or burnt.
  4. AlexD13
    298
    85
    Jun 13, 2016
    If the board is burnt, can it be replaced/fixed?
  5. 6cuda6
    259
    176
    Oct 9, 2020
    Sure but it may be cheaper just to replace it with a good used one......first things first...double check your dash cluster harness connections and make sure nothing is loose then go from there.
  6. Snailexpress
    2,675
    6,068
    Apr 28, 2014
    Rocky
    I'm not 100% sure but I think instrument cluster need to be reprogrammed.
  7. Inderjit
    Inderjit Heavy Load Member
    716
    703
    Sep 17, 2017
    Yes a Volvo instrument cluster requires programming.
  8. 6cuda6
    259
    176
    Oct 9, 2020
    I suspect he is using his original cluster therefore i don't believe it should need a reprogram ...could be wrong as its been a while. If he changes it, for sure it will need to be reprogramed....
  9. jayfarmlaw
    jayfarmlaw Bobtail Member
    30
    11
    Dec 12, 2020
    Not sure what year truck you have but Volvo clusters are pretty notorious for developing gremlins for bad contact at the contact points. There are several companies on EBay that resolder them. My 99 has three separate light wires that may or may not work at any given time. A pursuasive whack on the magic spot will sometimes bring them back, a bumpy road, or nothing at all will fix the problem. If the cluster is lose you can wiggle the connections on the back as well. My fuel gauge, air buzzer, high beam indicator, back lights, signal indicators, and idiot lights may or may not work at any given point.
    It was going to be $300 to get it resoldered but then I blew out a knee and a clutch on a tractor in the same week.....
    Good luck,
    Jay
