volvo d13 rear motor mounts
Discussion in 'Volvo Forum' started by ratabekov, Feb 27, 2020.
  1. ratabekov
    ratabekov Bobtail Member
    18
    7
    Sep 1, 2015
    How hard to replace them? Can i jack up the back of the I-shift transmission to get the weight off the mounts?, what are the torque specs for the 2 main bolts and 6 bolts to the frame? Thanks in advance
    KB3MMX Thanks this.
  3. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    A little pain but not to bad. Put jack right under clutch housing remove top bolts mount engine to mounts remove bolts for mounts to engine 2 90degree need to be removed to get out mounts remove 6 mount bolts put new mounts reverse order locators every bolt also need to take off steer mudguard for ease of working need 1 1/6 wrench 1 3/16 socket 21 socket 24 socket and 18 wrench good jack. Good luck
    KB3MMX and 05vnl670 Thank this.
  4. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    I meant loctite every bolt
    KB3MMX Thanks this.
  5. ratabekov
    18
    7
    Sep 1, 2015
    Thanks nasriza. Did them on Saturday. it wasn't easy by any means. took me 6 hours. Passenger side had 2 coolant lines for a def doser on the way and had to take dpf bellow pipe to get access to the top 2 bolts driver side had a bunch of airlines covering access to the frame mounting bolts. and to slide them in and out was like solving a puzzle. Did not do lock tight though, did not think about it, may have to revisit later
    KB3MMX Thanks this.
  6. 401-Alex
    401-Alex Light Load Member
    258
    278
    Nov 25, 2013
    401
    nasriza how hard us a d12 front engine mount along with 2 transmission mounts? On a 13 speed? And any ideas on a rattling noise out of the shifter in the high range with splitter in hi?
  7. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    depends on year front mount need to take out to do front mount properly and safely there is a way to sneak it but easier to remove cooling pack. No trans mount unless it’s a 2000 or 99 d12. Rattling noise might be shifter bushing or maybe some bearing in the trans getting a little weak.
    KB3MMX and 401-Alex Thank this.
  8. 401-Alex
    258
    278
    Nov 25, 2013
    401
    Its an 05 670 I've heard you and Jack the engine up with crossed finger to change the front mount. And the transmission mounts are actually rear engine mounts. Is it realistic to open the transmission for repair or just replace it? I've been told just get a remanufactured. Problem is it is a lkq remanufactured. 6 months out of warranty started making noise. I have thought its a spun bearing or one going bad on the. Aux. Trans.
  9. 05vnl670
    05vnl670 Light Load Member
    165
    60
    Feb 17, 2013
    I’m about to do the this job on Saturday. Any gasket I would need. Do i have to take any exhaust components? Drain coolant?
    Thanks in advance .
  10. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    Possibly exhaust bellows gaskets and clamps might have to remove for ease of access other than that nothing.
    KB3MMX Thanks this.
  11. 05vnl670
    165
    60
    Feb 17, 2013
    The most of the work is done thru dog house or under truck?
