Volvo d13 often parked regen and quick soot level increase
Discussion in 'Volvo Forum' started by Pawel-pl, Jan 6, 2019.
  1. Pawel-pl
    Pawel-pl Light Load Member
    66
    30
    Jul 3, 2017
    Hello,
    On one of the trucks, volvo 780 with d13 engine. I noticed that when in morning before I start driving soot level shows on about 25% and then in about 30-45 minutes it jumps to 70-80% and it asks for parked regen. Its happening usually daily.
    Is ti normall to have soot level go up so quickly? I dont think that parked regen should be happening daily?
    Edit:
    I forgot to say that today when the soot level jumped high in about of 25 minutes of hwy driving in got back to 20%
    KB3MMX Thanks this.
  3. Misesian
    Misesian Road Train Member
    2,078
    3,178
    May 21, 2014
    Nothwest Arkansas
    How old, how many miles, and when was the DPF serviced? If you idle all night it is not uncommon to regen shortly after reaching highway speed. You either have a plugged DPF that needs service or you have something wrong with the air to fuel ratio creating a lot of soot. I drove a 2012 Volvo D13 as a company driver for a year and a half and it never had a parked regen.
    86scotty and KB3MMX Thank this.
  4. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    DPF clogged with ash and / or ruined from coolant contamination
  5. benrab
    benrab Medium Load Member
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    We saw sometimes the insulation inside of the flexible pipe at the turbo outlet broke and fall on the top of the DPF and generate a situation like you explain.
    KB3MMX and Newto Trucking Thank this.
  6. HarrodTech
    HarrodTech Bobtail Member
    12
    10
    Nov 28, 2018
    Kentucky
    Could be a faulty Soot level sensor I have 2017 D13's and newer. We have been crawling all over our Regen Systems lately. Now sure what type of system you have, I have the stackable cannisters on our older models and the 2018 have a huge side mount.
    KB3MMX Thanks this.
  7. Pawel-pl
    66
    30
    Jul 3, 2017
    Thanks for all replys, the solution was changing batteries. I checked them just in case and they were way to low so I decided to change them. Now 3 days on road and no issues with truck at all.
    uncleal13, KB3MMX and HarrodTech Thank this.
  8. Adil84
    Adil84 Bobtail Member
    49
    5
    Dec 4, 2013
  9. Adil84
    49
    5
    Dec 4, 2013
    Hi bro can you please tell me where is this soot level sensor located on 2013 volvo D13 ?
  10. Adil84
    49
    5
    Dec 4, 2013
  11. Adil84
    49
    5
    Dec 4, 2013
    Hi bro
    Im having same problem my 2013 volvo d13 asking for parked regen almost every 2 days after the regen fone and drove for about 2 hours i see soot level going up quickly i took it to dealer they changed dpf dif sensor , egr delta p sensor , imap sensor, venturi pipe, 7th injector ,ahi module, baked dpf but still have same problem its driving me crazy . Truck has 543 k miles . Def doser , nox sensors all are good . Any idea on how you fixed your problem ?
