Volvo d13 Fault code 411 fmi 5
Discussion in 'Volvo Forum' started by KirshaunW., Jul 18, 2017.
  1. KirshaunW.
    KirshaunW. Bobtail Member
    14
    7
    Apr 30, 2015
    Statesboro, GA
    im getting a 411 fmi 5 I'm pulling up Egr sampling Range failed ? Any ideas ? When I get to speeds upwards of 65-70 I get some shaking but when I ease off accelerator it goes away sometimes I don't have any shaking at all I also notice when my turbo kicks in the shaking also goes away it kicks in and out inconsistently I just want to get to the bottom and yes it's affecting my mpgs.
    KB3MMX Thanks this.
  3. Sharky88
    Sharky88 Heavy Load Member
    715
    851
    Sep 25, 2013
    Could be a couple of things. When was this he last time you had the dpf cleaned? Might be a temp sensor going bad.
    KirshaunW. Thanks this.
  4. benrab
    benrab Medium Load Member
    326
    238
    Apr 5, 2015
    Quebec ,Canada
    Base on your Code Pid 411 FMI 5 , the circuit of the egr differential pressure sensor is bad, very often the sensor itself generate that type of problem.
    It's possible because the egr sensor reading is not working like it suppose your engine can ingest to much egr gas (exhaust)
    KB3MMX and KirshaunW. Thank this.
  5. KirshaunW.
    14
    7
    Apr 30, 2015
    Statesboro, GA
    Thanks guys I ordered and installed the part and that code went away.
    AlexD13, Doealex and KB3MMX Thank this.
  6. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,588
    Dec 29, 2014
    Orrstown, PA
    Awesome!
    How much was the cost?
  7. Davy
    Davy Bobtail Member
    Which parts do you replace?
  8. Socal Xpress
    1,855
    1,958
    Dec 6, 2014
    Los Angeles, Ca
    The delta p sensor (aka differential pressure sensor) on the Ventri tube.
    @Davy
  9. Benny28
    Benny28 Bobtail Member
    Hi buddy I have same issue my truck shaking in 65 or after and gave me code fmi 5 what part did you change?
  10. KirshaunW.
    14
    7
    Apr 30, 2015
    Statesboro, GA
    Shaking is usually injectors
