Volvo d13 engine swap
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by alexhemi7, Apr 19, 2019.
  1. alexhemi7
    alexhemi7 Bobtail Member
    10
    4
    Mar 24, 2010
    Hi I am looking for some advice on a volvo d13. I have a 2008 volvo with a d13 dpf engine that blew. I dont want to rebuild it. I also have a 2011 with a d13 engine with def that was in an accident and the cab is bad. Can i swap the engine from the 2011to the 2008? If i swap it can i eliminate the def and keep the dpf only? Thanks
  3. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    Legally ,you can.
    Goodysnap Thanks this.
  4. Oneel998
    Oneel998 Bobtail Member
    22
    6
    May 21, 2019
    I think they are both H series engines. Youll have a configuration mismatch, which wont mean much to you until you need it programed. Whatever parameters are on the old engine will swap to your new truck, speed gov. etc. idk about the deletes.
  5. alexhemi7
    10
    4
    Mar 24, 2010
    I sold everything. Don't have the time to swap. Thank you.
    Matt1924 Thanks this.
  6. Oneel998
    22
    6
    May 21, 2019
    lol well I tried. Good luck!
  7. iandun1979
    iandun1979 Bobtail Member
    Jul 2, 2020
    I have a 2010 volvo D13 VNL 780 I want to swap out the motor for a 2016 D13 I am keeping all my old ECM and controls will the engine work in my truck does anyone know >??
  8. daf105paccar
    6,564
    7,293
    Apr 15, 2012
    @Goodysnap
    @nasriza
  9. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    It doesn’t work valve cover will not fit eactly same just the block is the same. Everything else from the 16 engine will work.
    daf105paccar and Goodysnap Thank this.
