Volvo d13 a/c blowing hot
Discussion in 'Volvo Forum' started by Imani100, Jul 25, 2020.
  1. Imani100
    Imani100 Light Load Member
    116
    27
    Mar 12, 2017
    Chicago
    I’ve had my system recharged and everything checked, the ac always works some days and some it doesn’t. Everything was checked and the shop is confused and seems like they just want to throw parts at it just because they don’t know. Any common problems like this? When it works it blows perfect seems like when i turn the truck off for the next day it might not work for a few days
  3. poniikyanion
    poniikyanion Light Load Member
    69
    14
    Nov 23, 2009
    Newark, NJ
    I have a similar problem with my 05 but the last few days the ac actually have worked flawlessly when the outside temp hit almost 95.
    Usually in my case it would resume to work if I just restart the truck. So I now suspect moisture in the ac line even though the dryer indicator is green.
    The theory is that when the moisture in the ac line begin to freeze at the evaporator coil it caused blockage in the high pressure side.
  4. Imani100
    116
    27
    Mar 12, 2017
    Chicago
    Yeah this sucks these guys replaced the dryer checked everything i guess I’ll just replace the ac compressor one last time maybe the last one was faulty....but i don’t get it wouldn’t it just not work at all
  5. boneebone
    boneebone Road Train Member
    2,294
    2,365
    Mar 13, 2009
    Did you replace the expansion valve for the cab and the sleeper and replace the receiver drier?
    KB3MMX Thanks this.
  6. Imani100
    116
    27
    Mar 12, 2017
    Chicago
    Yeah they replaced the one for the sleeper because it was leaking alittle and refilled it didn’t work that day but the next day it did, it magically works some days and some it doesn’t and they also replaced the drier too
    KB3MMX Thanks this.
  7. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    check to see if the connections on the ac compressor r losee sometimes the pins do not make good contact.
    KB3MMX and Imani100 Thank this.
  8. Russian Rabbit
    Russian Rabbit Road Train Member
    1,701
    1,633
    Jan 3, 2016
    can you post some pics of this?
  9. Russian Rabbit
    1,701
    1,633
    Jan 3, 2016
    EMERGENCY:
    What other ideas, from most likely to least likely?
    2) Please be very detailed and if possible provide pictures.
  10. Imani100
    116
    27
    Mar 12, 2017
    Chicago
    Most likely he’s talking about this
  11. Zen Logistics
    Zen Logistics Bobtail Member
    Jul 23, 2021
    Hey did that end up working im having the same issue on my 2011
    KB3MMX Thanks this.
