just like the title says whats your take on this engine. Good/Bad/Indifferent. I was looking at a truck today and thats the engine that it had, not having delt with the volvo engines, my company uses cummins engines in all but one of our trucks.
Volvo D12- whats your take
Discussion in 'Trucks [ Eighteen Wheelers ]' started by juanveldez, Apr 30, 2007.
I am a company driver in a 06 Volvo 670 with a d12.
It is gutless as spec-ed out by my company. It is accompanied by a 9 speed eaton fuller.
Motor has been completely reliable, I have had it for 100,000 miles, and the only thing dont to it was a valve adjustment, and a egr or something on the exhaust side, that caused coolant to leak into the exhaust.
OK, on my fuel mileage...
I get right about 6.0 per trip, some times more, some times less. Truck is governed at 65, and will get closer to 7mpg if I am behaving in Ohio. I also IDLE The truck 100% of the time, I tend not to use the TAS system.
If I was an owner operator I would want a motor similar to this, it is gutless, but in most cases you make more money be driving slower than faster.
Something I heard on this show the other day...
When Buying a new truck....
1. Have truck dyno tested, with blowby test and oil analysis.
2. Have someone, not the dealer, go over the truck and list possible problems.
3. Get a complete history printed off from the computer, this will tell, lifetime MPG, Idle Time, average MPH, average RPM, any codes, etc.
check out kevinonxm.com he has a PDF list of trucks spec-ed out for maximum fuel mileage.....remember, 1mpg a year will save you 8-12k in fuel per year.
K -
thanks for the info earth, my last truck was a 00 volvo with a 350 hp cummins n14 plus. for the work that I do that truck was compleatly gutless. go figure a truck that was made to pull 80,000 pulling on average 142,000 in a very hilly part of the country doesn't work out to well. it was a good truck when I was pulling the odd van load as a bit o extra money earned, but as for pulling my 6 axle not a good match.
The D12 is a decent engine. Volvo, like most european makers, build engines to get good fuel mileage rather than being the fastest on the block. European trucks generally are limited to 80-90 km/h so they're slow going but when you're paying $5-6/gallon for fuel and a full tank will cost you a grand or more, you're going to want the most efficient engine possible.
I couldnt agree more. it almost seems that if you were in the long run going to be able to save any kind of money it would be in good solid planning and fuel conservation.
Hope this was helpful also Volvo engine don't smoke like other engine i got pulled over with blown egr in new jersey scale and passed with flying colors no black smoke. i am running experiment to see the best way to get 9mpg and above with load since i can get that with a tail wind and running from Winnipeg to chicago as i did last week.Last edited: Aug 5, 2012
Really the best was D12C Euro-II/III w/o EGR. D12A was a good mechanically engine, but too simple (I'd say primitive ECM).
D12C ECM has one weak thing - Voltage converter and only sourse to change it is JY faulty ECM
