Hey all.
On my D13 450K miles I've recently replaced turbo and engine speed sensor.
The issue I am dealing with now, started at the same time my turbo was going bad and I thought it was related, but looks like it's not.
While pulling under load in the range of 1200-1400 rpm It feels like something is slipping. Truck would shake, kick a bit like it would get in small pot hole. No noises of any kind.
Is it clutch going bad?
Any other ideas?
Volvo D 13 iShift Clutch issue???
Discussion in 'Volvo Forum' started by tserberis, Jan 19, 2017.
Page 1 of 4
What year is the truck? Are you seeing the needle flutter? No codes? Is the truck hard to start?
Not hard to start now, but it was a few times after recent oil change. Had two code for crankshaft position sensor.
Just got those same two codes this morning for Crankshaft Position Sensor again.
But I thought that is that engine speed sensor that Volvo replaced. Maybe harness issue???
Needle Flutter? Did you mean the rpm? Just a bit when it slips. -
possible clutch issue volvo should be able to tell with ptt software other than that it could also be and i hate to say it cuz i sound like a broken record but it could be coming from injectors as well.
BigTennOTR, KB3MMX, Socal Xpress and 1 other person Thank this. -
I'll take injectors over clutch, cause they covered
clutch is around $4K out of the pocket -
well they just have to properly diagnose with that kind of milage it's kind of a far fetch on clutch but it is a possibility they should be able to tell easy ptt makes it dummy proof if you need a clutch or not
it should be more than 4k if they replace since they are there replace actuator for cltuch as well just incase so u can save labor when actuator goes bad just have to pay extra parts around 900
KB3MMX Thanks this. -
Yes and no depends sometimes they have a flat spot in a certain speed.
It was giving me a headache last night and today had yet to experience it.
Can it actually be because of the glitchy crankshaft position sensor?
Page 1 of 4
