Volvo Clutch Problem
Discussion in 'Trucks [ Eighteen Wheelers ]' started by haider99, Aug 4, 2016.
  1. haider99
    haider99 Medium Load Member
    685
    108
    I have a 07 volvo with 10 speed eaton. Today my driver while at pickup destination, the pedal got really hard all of a sudden and he could not put it into a gear easily. He managed to bring it out of the yard but I don't think he should be driving to a shop like this.
    Any suggestions on what to look for and how to bring it to a shop?
    Thanks
  3. BigPerm
    BigPerm Medium Load Member
    Linkage...Prolly ok to drive to a shop if he knows how to not use clutch when shifting.
  4. j_martell
    j_martell Light Load Member
    284
    184
    Jun 12, 2014
    Centre Wellington, Ontario
    ....are most Volvo's not hydraulic clutch?
    Every one I've seen was.....
    Duckman1005 Thanks this.
  5. BigPerm
    Could be...only driven one for very short time & dumb me...I should know...if so..
    still cross shafts fork, etc.
  6. haider99
    685
    108
    Hydraulic clutch.
    The service guy said its the clutch... clutch is all red
  7. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,432
    Aug 26, 2014
    I have seen that caused by the hydraulic system and there is a post on here from someone else. Could be a bad master or slave cylinder.
    What is clutch is all red?
  8. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    There is a pin that connects the shaft to the fork, same pin that is used for the brakes on the truck. Codder key breaks off and is hard to push and does not fully engage.
    Replace pin and use a heavier/thicker key.
  9. haider99
    685
    108
    I will be talking to the mechanic tomorrow. Exactly what should I be saying to him? Service call person said the clutch needs to be changed because its all red.
    There is no oil leak.
  10. BigPerm
    WTF..RED?? Please...insist a on an understandable explanation of "the clutch is red". 20+ year parts/service manager here.
    I'm cornfused.
  11. haider99
    685
    108
    I didnt see the clutch, my driver and mechanic saw it and said its burnt.
    The truck is 400 miles away
    My driver slowly moved the truck to a shop near by. It stays in one gear and brakes don't really work
