Volvo applying brakes itself
Discussion in 'Trucks [ Eighteen Wheelers ]' started by MrProDriver, Sep 25, 2019.
  1. MrProDriver
    MrProDriver Bobtail Member
    4
    Hey guys! I have 2011 Volvo vnl 780 and my brakes activates itself while driving or at idle. Called to 10 volvo dealers and Nobody knows the answer. Please help, maybe you had a Sane problem
    when idling, for no reason, bumps off from cruise control, brake lights come on;
    -when driving, starts braking without me touching the brake pedal, and after 8-10 seconds, comes back to normal
    Already replaced the brake pedal valve and brake pedal switch. No fault codes on tester
    Any ideas? Anybody ever heard of this problem? Thank you very much guys!
  3. mhyn
    mhyn Road Train Member
    4,255
    4,510
    Dec 29, 2008
    Northridge, CA
    You may have an evil spirit in your truck. You need to see an exorcist asap. Meanwhile keep garlic in slipper and throw salt on floor.
    kemosabi49 Thanks this.
  4. kemosabi49
    10,435
    44,376
    Jan 13, 2013
    SW Arkansas
  5. Bakerman
    Bakerman Road Train Member
    4,663
    8,812
    Jan 27, 2013
    Phoenix, AZ
    How about the brake pedal spring that holds it up off of the switch?
  6. MrProDriver
    4
    It has normal play, I even lift the pedal up and air still applying to the brakes
  7. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Water/corrosion in the Diagnostic port? Or other place in the J1939 data link.
  8. starmac
    starmac Road Train Member
    6,639
    12,528
    Apr 11, 2019
    Fairbanks Ak
    LOL, I don't have a clue what is going on with yours, but if it is kicking it off of cruise, I am betting some signal is going through the computer to do it.
    Back before electronic days, I had a customer that had a truck, that would turn it's head lights on randomlly, usually when parked at night. He said it was possessed. lol
    Any way, I decided it was the dimmer switch on the column, and he left it for me to repair. When I closed up that night, the lights were on, so I disconnected all the grounds on the batteries. I was called out in the middle of the night for a wecker or service call and when I got to the shop, the lights were on again. Now I was beginning to think he just may be right. lol
    the wind was howling that night, and it must have rocked that cabover enough to get one og the ground cables to move back far enough to touch the battery terminal. lol
    magoo68 and blairandgretchen Thank this.
  9. MrProDriver
    4
    Cruise control will deactivate everytime when you hit the brake. While in idle mode I can see the brake pressure gauge showing 10-15 pounds of pressure and stop lights comes on. So it has nothing to do with it. My bet is some brake valve but I'm not sure which one
  10. Rubber duck kw
    6,092
    17,685
    Dec 9, 2017
    Does it have any sort of collision avoidance system, if so I'd start there.
    rabbiporkchop and lester Thank this.
  11. MrProDriver
    4
    Its 2011 model, I don't think they they had that system that year
