Volvo 780 upper bunk window
Discussion in 'Experienced Truckers' Advice' started by Midnightrider909, Mar 25, 2019.
  1. Midnightrider909
    Midnightrider909 Road Train Member
    2,383
    9,599
    Oct 26, 2016
    I can’t figure how to open my upper window in my Volvo 780. In the Cascadia I used to drive it was easy to open with a knob but this one has a lever in the bottom and it’s really hard to move it and I’m kind of scared the window is going to fall out if I do. Can this window be opened or is it just to be used for emergency egress? From the outside it looks like there is a vent underneath each window. Is this functional or is it just for looks?
  3. S M D
    S M D Road Train Member
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    Twist left to open twist right to close.
    I believe it was
    Socal Xpress Thanks this.
  4. Midnightrider909
    2,383
    9,599
    Oct 26, 2016
    So there’s a twist involved? I just tried to slide the lever and it was like it was fixed in place and I was scared to put more force into it.
  5. Moosetek13
    Moosetek13 Road Train Member
    14,520
    17,977
    Nov 1, 2010
    Burnsville, MN
    The vent is the only thing that opens. The window itself does not open.
  6. Midnightrider909
    2,383
    9,599
    Oct 26, 2016
    How does the vent open?
  7. S M D
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    Post a picture of what window you’re talking about?
    If it’s the top bunk one or the bottom one in a 780 then you twist the knob!
    If it’s. 670 you twist the top bunk one still but the bottom one will be a push lever.
  8. S M D
    2,396
    3,406
    Mar 15, 2012
    sacramento ca
    Never seen a Volvo 780 where the top windows didn’t open.
  9. loudtom
    loudtom Road Train Member
    1,717
    2,800
    Aug 26, 2016
    The 780 I drive does not have top windows that open. It's a vent with a lever that goes up and down. Up position has a C, down position has an O.
    86scotty and Midnightrider909 Thank this.
  10. Midnightrider909
    2,383
    9,599
    Oct 26, 2016
    Mine too! I just tried it. Mystery solved.
  11. I_JustWannaGetThere
    I_JustWannaGetThere Bobtail Member
    Apr 26, 2019
    Does anyone know if they make an aftermarket window that DOES open? The vents are BS
    Midnightrider909 Thanks this.
