Volvo 780 Audible warning speaker.......not working.
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Steve Singfield, Aug 13, 2013.
  1. Steve Singfield
    Steve Singfield Bobtail Member
    So, I get my 09 Volvo to the main dealers in Saskatoon for a quick service, general checks etc, oil and fuel filters.
    Doing my circle check this morning, I noticed the buzzer did not sound with the usual screech telling me I had low air, and the blinkers were not clicking,
    I mentioned this to Volvo, they looked into it, and told me that though all the electrics were good, it was just the speaker that was blown, I nearly fell off my chair when they said the speaker module would cost $1,200, plus fitting, plus taxes.....surely I can buy a speaker from Radio shack, Walmart etc,or pull one out of an old radio, and solder in a new speaker? Can any one give me advice please? I have to try and repair this problem myself, I cannot justify this amount of cash for a speaker, ....does the dashboard have to come apart? I can hear it about my shin area, surely its reasonably accessible, help please.
  3. me myself and I
    me myself and I Heavy Load Member
    731
    312
    Oct 5, 2009
    vernon hills,Il
    Its not a speaker. Its a part of instruments cluster, and they want to replace it. I've heard that there is a way to repair it, but dealer will only replace entire thing.
  4. lastgoodusername
    lastgoodusername Medium Load Member
    444
    215
    Dec 18, 2008
    central NC
    get an inline low air warning switch, plumb it into the air line going into the gauge. install buzzer leads to ign hot circuit and the other to a ground. problem solved for $20.
  5. marek4792
    marek4792 Light Load Member
    62
    31
    Mar 21, 2011
    Chicago, IL
    pull the cluster out and open up the back cover you should be able to remove the old speaker and soder a new one on it no problem.
    @lastgoodusername, it's all electrical no air lines going into the cluster.
  6. lastgoodusername
    444
    215
    Dec 18, 2008
    central NC
    the airline i am talking about goes into either one of the air gauges.
  7. dphillips
    dphillips Light Load Member
    82
    8
    May 14, 2013
    Does anyone know where you can get a replacement speaker from
  8. asavage1576
    asavage1576 Light Load Member
    62
    36
    Mar 18, 2013
    Dallas,Tx
    You can't just replace the speaker. And unless you have extensive experience with circuit board repair I would not suggest repairing it. Either replace the cluster or rig up a home made buzzer. In our shop we replace the cluster.
  9. blanco
    blanco Road Train Member
    1,221
    296
    Nov 20, 2009
    Gwinnett County, GA
    What happened to good ol relays and fuses and such. I would do like this.
  10. Pablo-UA
    Pablo-UA Road Train Member
    7,604
    1,642
    Oct 11, 2010
    Borispol, Ukraine
    remove instrumental cluster, off the back cover and U see speaker, the same like DAF/KW/Mack/Renault.... it is small 32 ohm speacker, chek it with DVOM for bad coil. if coil is ok and no soldering deffects - replace amplifier chip
    dphillips Thanks this.
  11. Gram25
    Gram25 Bobtail Member
    21
    Oct 23, 2015
    I know this is an old thread but we had this same problem and it might help someone else having the same problem.
    We disconnected the battery cables for 30 minutes to reset the computer and everything went back to working as normal. All sounds came back.
    4noReason Thanks this.
