Hello guys have questions about Volo 670 2014 D13 Ishift 455 Hp
Looking to buy this one can't find it online Sor far I found 425 Hp but I'm not sure if there's big difference between 455 Hp or 425 Hp when you pulling 53 trailer with 40.000 loads . And for used tractor with
Mileage 500.000 is that too much mileage or okay and what the average for price for Volvo 670 2014 D13 455 Hp Ishift thank you guys appreciate your answers
Volvo 670 D13
Discussion in 'Ask An Owner Operator' started by JORTRUCK, Mar 9, 2017.
If you are routinely hauling at gross weight I would look at 475 HP or 500 . I haul roughly half the time at 40k I have a 455 hp 10 speed 2013 and it's not terrible on the hills but I could use a bit more . At 425 hp and 500k that motor has probably taken a beating . Look at something In the 275- 300k range you'll probably pay low 60s but you won't have any major work for your first year . At 500k you're walking into some serious repair bills .
500k on a D13 is nothing. It'll live about 3x that mileage.
You won't see much performance difference between those two motors HP ....but .. you'll want to check the torque spec. The lower tq ratings won't pull as well obviously. -
Yah appreciate so like you said between 425Hp and 455 Hp not big difference but actually no have experience about the torque spece What good number for the torque spece For this volvo 670 2014 ishift to make the truck pull and climb smoothly ?
This is the torque spec.
Engine Make: VOLVO
Engine Model: VED13
Horsepower: 455
Trans Speed: 12 Speed ishift
Trans: VOLVO ATO2612D
Ratio: 2.64
Sleeper Size: 61
# Bunks: 2
Sleeper: RAISEDROOF
P/S: Y
A/C: Y
APU: N
Suspension: A/RIDE
Jake Brake: Y
Brakes:
5th Wheel: A
Tire Size: 22.5
Wheel Base: 221
Front Axle: 12,500 LBS
Rear Axle: 40,000 LBS
Steer Wheel Type: AL
Rear Wheel Type: AL
Cab Configuration: CON
Equipment Type: TRAC -
Since it has an Ishift thats the Xe package. It can be the eco torque. Wich gives you 2 differant torque specs.
Ok so this site has this information and can be found but I will post it here for you.
Fan clutch will need to be replaced at about 500k. If this hasn't been done you risk taking out the radiator. The water pump began to weep so I replaced both at the sametime.
Injector cups are the biggest flaw of this engine. Now your truck more then likely had the updated stainless steel cups from the factory. But eventually you may end up dropping a new 6 pack at some point.
The breather systems has a seal that likes to go bad and leaks a ridiculous amount of oil.
The normal stuff like Dpf cleaning and Def tank cleaning. I own a 2010 so the Def maintenance is something I dont worry about. Someone will chime in.Last edited: Mar 10, 2017
Reason for edit: Derp more derpKB3MMX Thanks this. -
When I was a company driver they had the 670's with 425 HP geared at 2.64 ratio. Even those had plenty of power for the passes on the west coast.
I would say that it is always important to ask for the maintenance records of any used truck you buy. Being able to review the types of repairs will give you an idea if a truck is defective in a particular component.
Most fleet run trucks will not perform the manufacturer's recommended service intervals, other then basic oil change and lube.
I am including an attachment of Volvo's service intervals as an example. I as a 1 truck operator am following the maintenance schedule to a T, except I utilize a shorter interval on the oil changes.
My truck is approaching 150k miles and I already have the estimate and schedule in place for the maintenance items recommended by Volvo at 150k miles. The truck is my livelihood and with proper care these trucks should go a long ways in providing dependable service.
Good luck.Attached Files:
Couple other factors to consider:
Where was this truck mainly operated? Trucks that spend more time in salty regions where road salt and snow accumulate means there maybe higher corrosion, especially lower on the engine and frame. lower radiator hoses corrode more quickly. Suspension mounts, oil pan nuts..etc can be problematic at an advanced age.
Was the truck beat to death on a regular basis? PA and NY are places where trucks take a pounding because the roads are older and maintenance isn't as plentiful at times. Was this truck driven off road? How much idle time?
Mileage data alone isn't enough to make a purchase decision. You really need as much data as possible, with proof. Taking someone's word (like a salesman) for it isn't a reliable business practice. -
I have a 2011 D13 that's rated at 425. The dealership says they can increase it to 475 for $415. I know the torque will increase because they were concerned about the limitations of the tranny but the factory gave the green light. Should I bother or will there be no real noticable difference pulling the hills?
Used trucks always complicated to find out everything about it nothing like the new. But the price crazy over 100k for now one Looking around maximum price 55k for used one but sure like the guy said malieag not enough to check a lot of stuff need to check and I think for use one dealer give warranty I'm not sure
