Volvo '08 VNL 780 Hard Steering
Discussion in 'Volvo Forum' started by Cpervanic81, Aug 25, 2017.
  1. Cpervanic81
    Cpervanic81 Bobtail Member
    Hey guys! Hoping for some suggestions! 2008 Volvo VNL 780 hard turn both ways. I changed the power steering pump and the gear box and still the same problem. Steering column seems fine. Any suggestions?
  3. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Return power steering line may need to be replaced if it has not been changed yet
    BUMBACLADWAR and Cpervanic81 Thank this.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Some vehicles have a filter in the steering fluid reservoir,
    Cpervanic81 Thanks this.
  5. nax
    nax Road Train Member
    1,999
    2,253
    Dec 14, 2016
    Flush the fluid & bleed the system.
    Old fluid may lose it's hydraulic "power" and also air may reduce the effectiveness of the energy/effort transfer.
  6. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    The steering pump could be worn out, leaking I posted link below 3 years ago, i have same truck 2008/780 . The power steering and fuel pump are spinning on same shaft,don't make my mistake replacing one pump only; get a combo because the shaft usually goes out of balance damaging both pumps.
    See here, you can buy this fuel pump (or steer )only sold separately only like this , but i don't recommend ;[​IMG]
    get this combo, replace both same time; [​IMG]
    Volvo D13 fuel pump replacement
    Jazz1 and KB3MMX Thank this.
  7. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    usually just change the filter in the power steering reservoir. thats most of the time the actual problem not the pump.
    BUMBACLADWAR Thanks this.
  8. nax
    1,999
    2,253
    Dec 14, 2016
    @nasriza ....quick question...does the D12 (1998) have a filter in the p/steering system. If so, where is it?
  9. Johny41
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    I remember watching this video loaded by OTR;
  10. nax
    1,999
    2,253
    Dec 14, 2016
  11. Goodysnap
    Goodysnap Road Train Member
    3,694
    8,948
    Jul 12, 2017
    Stop throwing parts at it and have it properly diagnosed. Start by supporting the front end on stands and separate the drag link from the pitman arm. Insure that the wheels will turn from lock to lock(full left to full right) by hand with little effort if any. If they are stuck you likely have a frozen king pin or front end component that the power steering system cannot overcome. Follow up by have the steering system pressure and flow tested to determine where the hydraulic system is lacking. I've seen everything from plastic plugs stuck inside reservoirs to hoses collapsed internally causing restrictions in the fluid flow. These restrictions can be on either side of the pump or the gear.
    Good Luck
