VNL 780 2015 - I-Shift problem maybe transmission.
Discussion in 'Volvo Forum' started by Battlecruiser, Dec 29, 2018.
  1. Battlecruiser
    Battlecruiser Bobtail Member
    19
    10
    Nov 30, 2017
    The problem I'm having is when I select gear into "Drive" from Neutral it would go straight into 5th gear but I don't hear the gear switch. After this happens I go into Reverse-1 and not even a backup sound from the rear Reverse speaker. When Pressing the manual (+/-) buttons it would sometimes switch into gear and start moving. When I start slowing down and coming to a complete stop it would go into 5th gear again and just gets stuck there, stepping on the pedal doesn't do anything until I switch around gears manually going from 5th to 4th etc... I can see the gears switching on the dashboard but doesn't feel like its switching. When I switch into Neutral and throttle the RPM would move normally. When I'm in Drive and the dashboard is showing 5th gear, I hit the throttle and RPM doesn't move until I switch around gears up and down (it sometimes takes a while), when I actually hear the gear switch into gear then the RPM moves and the truck drives.
    Please if anyone has experienced this before or is familiar with this problem let me know what it could be. I was able to tow it to Volvo but they are backed up for 6 weeks and won't touch my truck if its something major. I still have warranty on my transmission, if the tranny is the problem then I guess I would have to wait.
    My truck is D13 2015 with 560k miles.
  3. nasriza
    nasriza Road Train Member
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    What’s your mileage if under 700k take it to Volvo most likely shift cover is done does the trans have any fault codes.
    KB3MMX Thanks this.
  4. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    He says 560k. Did you not read his post? Also, its already towed to a volvo dealer..shop is backed up with a 6 weeks wait. That is awful.
  5. QUALITYTRUCK
    1,801
    1,762
    Jun 14, 2009
    romulus,mi
    Take it easy Buddy. When someone is busy reading through multiple posts, and actually making suggestions on how to fix an issue, sometimes you miss information.
    KB3MMX and THE ROOKIE Thank this.
  6. Battlecruiser
    19
    10
    Nov 30, 2017
    No fault codes on the dashboard at all, the dealer said that when they scanned it it showed a gearbox code, they didn't tell me much. they just said it could be anything, they need to further diagnose it before giving any assumptions.
  7. Scooter Jones
    Scooter Jones Road Train Member
    9,551
    19,976
    Apr 19, 2011
    Did you schedule time for further diagnostics?
  8. stillwurkin
    1,756
    2,856
    Dec 2, 2017
    No exclamation point after "did one not read the post". The awful part is pertaining to a approximate 6 weeks wait to get truck looked at. That is unacceptable, unless the shop don't like him. I have no idea. Just happy i have a manual transmission.
  9. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Maybe next week you can call other volvo dealers to see if they have any better wait times and have the people that do I/shift work every day?
    KB3MMX and stillwurkin Thank this.
  10. nasriza
    2,397
    2,070
    Feb 1, 2013
    Chicago, IL
    being that this repair repair will cost usually a decent amount of $$$$ up to $20 k at times sometime it’s worth looking around for a different dealer depends on location very few people know how to work on these transmissions although Weller could repair and does sell reman I shifts so other than the dealer to go under warranty that is the most cost effective way
    KB3MMX Thanks this.
  11. Rickspacecommand
    Rickspacecommand Bobtail Member
    6
    7
    Dec 3, 2018
