Hi folks, I have a 1995 Kenworth t300. The VIN sticker on the door is worn and the number is only partially visible. There is a yellow tag above the visor that is visible, does anyone know of the VIN being stamped anywhere else on the truck? Frame cross member etc. Thank you in advance for any help. Have a nice day
VIN location?!
Discussion in 'Kenworth Forum' started by asolheim, May 17, 2022.
Vehicle registration paperwork
Insurance paperwork
Cab card
Check for a ‘line ticket’ glued inside the glove compartment(if there is one). -
Ck the top of the FT. Frame rails for the whole Vin # stamped on it ahead of the ft axle.
Paccar normally stamps the VIN on the passenger side frame rail, around the steer axle area.
They used to stamp it on the front bumper as well. Not sure if they still do or not. Used to have a VIN tags riveted on the bottom of the dash, above the clutch pedal too but that might have changed with time. -
Oxbow Thanks this.
I have seen the VIN stamped on the frame rail webb just ahead of the right rear
steer axle spring hanger bracket or on the left top frame flange just ahead of the fire wall. -
baha Thanks this.
AModelCat Thanks this.
