Vibration between 30 - 40 MPH
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Cbrannum, Oct 26, 2020.
  1. Cbrannum
    Cbrannum Bobtail Member
    10
    4
    Oct 26, 2020
    I have a 2017 Freightliner Cascadia that had developed a serious vibration starting softly at 30 MPH peaking at 35 MPH and then stopping around 40 MPH. I have checked tires and got them balanced. I am needing help figuring out what the next best thing to look at will be. Thank you.
  3. stillwurkin
    stillwurkin Road Train Member
    1,756
    2,856
    Dec 2, 2017
    Check driveline. U-joints etc. Do your engine rpms make a difference? Kinda slow speed for a vibration.
    User666, Cbrannum and LameMule Thank this.
  4. LameMule
    LameMule Road Train Member
    1,147
    7,399
    Jan 19, 2020
    Montana
    If it's a manual throw it in neutral when the vibration occurs and let it go to idle. Should help you isolate the issue a bit.
    I just had a similar vibration at 45 to 50 and it was u-joints. Pretty common and fairly easy to confirm by crawling underneath and giving everything a good tug. Check the carrier bearing while you're there.
    User666, Cbrannum and stillwurkin Thank this.
  5. Cbrannum
    10
    4
    Oct 26, 2020
    it is worse when accelerating and I’m not sure if vibration is the correct word. It more shakes violently.
  6. Cattleman84
    Cattleman84 Road Train Member
    9,869
    70,289
    Nov 1, 2017
    The Sticks, Idaho
    Shakes like a bouncing or shakes like the steering wheel skakes/jerks back amd forth?
  7. LameMule
    1,147
    7,399
    Jan 19, 2020
    Montana
    I've seen a rock between the drives cause a heck of a vibration but that's near impossible to overlook and not likely on a highway truck.
  8. stillwurkin
    1,756
    2,856
    Dec 2, 2017
    You sure you don't have a misfiring injector. Happened to me once and it shook the hood etc.
  9. stillwurkin
    1,756
    2,856
    Dec 2, 2017
    Yeah I popped a tire once with a rock in between.
  10. Cbrannum
    10
    4
    Oct 26, 2020
    It kind of feels like I’m sitting On one of those exercise machines that just shake you a lot when you stand on them. But worse.
  11. Cbrannum
    10
    4
    Oct 26, 2020
    I haven’t had the injectors checked yet. Never even crossed my mind that one could cause that. Thanks.
    stillwurkin Thanks this.
