Vibration 65-70 mph
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by OldeSkool, Jan 9, 2021.
  1. OldeSkool
    OldeSkool Road Train Member
    1,649
    4,495
    Jul 17, 2018
    New Hampshire
    My 17 Cascadia has developed a vibration in it. I hardly feel it at 60 mph but it definitely starts by 65 and by 70 it’s quite bad. I feel it in my steering wheel and in the seat, but it also has a roaring sound with it. My wife recently rode with me a few hours at 70mph and I finally slowed down to 65 because she couldn’t stand the noise and vibration.
    Now here’s what I’ve done. First I replaced the driveshaft carrier bearing since it had some slack. Next I put censatrac wheel balancers in the steer axle, and finally just replaced the steer tires but hasn’t helped at all. The drive tires are all nearly new, 90% tread.
    Could this be a U-joint? I don’t feel slack in any, but that’s about all I can come up with. Considering dropping the driveshaft and getting it balanced and U-joints checked. What do y’all think?
  3. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Mine roars but it happens around 16-1700 rpm range no mater what gear I’m in. Very harsh vibration.
  4. baha
    baha Road Train Member
    4,137
    2,835
    Jul 25, 2013
    ga
    Did it change at all with the new steering tires put on? did you grab the rear drive shaft and ft. and try to shake it both ways or get a bar and see if you can see any back and forth play in them , does it have the U/joints that do not take grease or the ones you can put grease in ck them before you grease them if they are that type, run a string from trans. u/joint cap back to u/joint cap at rear end run a string down from center u/joint cap just to see if center u/joint is in line with both ends of string, ck to be sure all u/joint caps are in line and not off by any, drive shafts will vib. if all u/joint caps are not in line!
  5. OldeSkool
    1,649
    4,495
    Jul 17, 2018
    New Hampshire
    Thanks I’ll try that. My u-joints are non greasable and no I didn’t notice any difference when I put the new tires on. I had a vibration around 35-45 mph that was fixed when I replaced the carrier bearing.
    Another Canadian driver and baha Thank this.
  6. SmallPackage
    5,278
    16,471
    Dec 20, 2019
    Marion Texas
    I’ve had one in the 1600-1700rpm at 45-50 mph for about 6 months now. Highway it cruises smooth.
    On the carrier the bearing itself was ok but the rubber was shot and the output yoke nut on the 13 speed trans got loose and the seal started to leak because of it.
    THERE WAS NO VIBE AT ALL before I replaced it and tightened the nut.
    I’ve replaced all the joints with no change. I even reused two of the joints on another truck because they were still good. No issues there. They only had 33,000 on them. Played with angles by shimming the carrier. Rear diff angles and ride height are spec.
    I believe after all the tests, checks, and things I’ve done that it is the trans. or the clutch. Something got worn when the rear bearing nut got loose. I don’t know how long it ran loose. If in 7 dir it is vibrating but when in 7 od at same speed it is noticeably harsher. The trans as far as I know has around 3 million on it. The clutch has around 670,000. They still function good and It’s drivable but annoying.
    Weird thing I can’t explain is when the fuel tanks are full the vibe is lighter. When they get around 1/2 full the vibe is much heavier/harsher.
  7. OldeSkool
    1,649
    4,495
    Jul 17, 2018
    New Hampshire
    Mine doesn’t seem related to RPM at all
  8. OldeSkool
    1,649
    4,495
    Jul 17, 2018
    New Hampshire
    Mine gets worse the lighter I am too. Bobtailing is the worst.
  9. SmallPackage
    5,278
    16,471
    Dec 20, 2019
    Marion Texas
    I’ve tested with or without trailer. No difference with this truck in that way.
  10. aussiejosh
    aussiejosh Road Train Member
    4,709
    5,408
    Aug 28, 2009
    Airlie Beach QLd
    The first thought was your steer tyres need a wheel balance yes something in there is out of sink that's for sure it should be smooth driving for you if everything was fine..
  11. ichudov
    ichudov Heavy Load Member
    742
    641
    Mar 14, 2012
    Berkeley, IL
    Does it happen both when you are pushing the gas pedal, vs when you let go of gas?
    Does it happen in neutral vs in gear?
    In my case the same exact symptom at 65 mph happened only when I apply the gas pedal , and it was a bad u-joint.
