Very simple answer to mounting CB, with no drilling holes in truck
Discussion in 'CB Radio Forum' started by Truck-N-Tech, Aug 12, 2012.
  1. Truck-N-Tech
    Truck-N-Tech Medium Load Member
    330
    429
    Sep 13, 2010
    In December of 2011, I was issued a brand new 2012 truck. I didn't want to damage anything by mounting my CB radio, plus I wanted the option of taking the radio out quickly, if I needed to. I came up with a good idea, which allows me to mount my CB, external speaker, and even a medium sized power inverter to the dashboard of my truck, with no damage to the truck.
    First I got a piece of 3/4 inch wood, and cut it to the size I wanted. Then I cut the wood at an angle on the back side, so it would follow the angle of the windshield. This gave me a nice platform to mount everything I wanted to. Then I mounted the CB, External speaker, and power inverter to the wood.
    On the back side of the wood, I screwed in t medium sized hooks, with the open side facing down. Then I got 2 small suction cups that stick to the windshield, and put the hooks on the wood into the handles of the suction cups. That keeps the back end of the wood level with the front end. Where the front end of the wood rests on the dashboard, I stuck a row of felt pads at the exact place the wood rested on the dash.
    When I start out my week, I simply attach the suction cups to the windshield, and hook the wood into the handles. Then I attach my Antenna coax, and I'm ready to roll. Total time to put the radio in is less than 2 minutes.
    I have a video on YouTube, where you can see this mount an action. You can't tell by the video, but there is a gap between the radio and the speaker, which keeps my line of sight clear for the spot mirror on my passenger side of the hood.
    The mount is nothing fancy, but it gets the job done. After 5 months use, you can not see even the slightest damage to the dash anywhere.
    Here's a link to the video I did. Remember, you are just looking at the mount, not my great camera work.
    http://youtu.be/ckLK9z1OhJE
    M818, Colorato and geppetto Thank this.
  3. flc120
    flc120 Heavy Load Member
    916
    122
    Jul 11, 2012
    Miami,FL (yeah i know :( )
    i have plenty of hole drilled by previous owners in my truck dam cb's why cant they just mount them up in the hole where they go.
    CBSPARKY and GAlanFink Thank this.
  4. GAlanFink
    GAlanFink Medium Load Member
    334
    271
    May 8, 2012
    Bucks County, PA
    My 2013 Freightshaker already comes with a place to mount the CB. All I did was get rid of the crappy antenna they provide and put some oil-cooled Wilson's there. Match dropped to nothing... no RF feedback at all - I was expecting to at least have to move the wire.
  5. Colorato
    Colorato Road Train Member
    1,336
    865
    Feb 22, 2011
    Another thing to use when you want to mount things without drilling holes is 3M double sided industrial tape. It can be bought anywhere and is very strong but can peel of without leaving a mess.
    CBSPARKY Thanks this.
  6. jessejamesdallas
    1,416
    855
    Oct 3, 2008
    Republic of Texas
    Yeah...And if you have a wreck, that radio, plywood, and speaker is going to turn into a missile flying around inside the Cab with you too!
    Motownfire Thanks this.
  7. Crazy37
    Crazy37 Light Load Member
    171
    240
    Feb 21, 2012
    Bullhead, Az
    Good ol Velcro works wonders too.
  8. Quickfarms
    Quickfarms Heavy Load Member
    898
    236
    May 29, 2012
    Los Angeles, Ca
    Mine was seatbelted into the passenger seat with the cooler and my backpack
  9. cuzzin it
    cuzzin it Road Train Member
    3,399
    7,785
    Jan 19, 2008
    Berea, KY
  10. mike5511
    mike5511 Road Train Member
    3,140
    1,523
    May 15, 2011
    NW Arkansas
    But nobody plans on having a wreck!!!!...........and yet they still happen???????
  11. Truck-N-Tech
    330
    429
    Sep 13, 2010
    All the items are very securely attached to the wood. If you look at the hooks, they are heavy enough to hold 100 pounds each. If you grab the wood, and pull it, you can't break the suction cups loose from the glass. If you hit something, and have extreme deceleration, The radio and wood would go away from you, not toward you. I would be more likely hurt from a flying metal clipboard, or my winch bar smacking me, than hurt from this radio and mount.
