Vents blowing hot air all the time
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by kestrel1, Jan 24, 2021.
  1. kestrel1
    kestrel1 Bobtail Member
    35
    10
    Jan 1, 2009
    Sacramento, CA
    Just thought I’d throw this one up here in case there’s a simple fix before send it to the shop. My 2016 KW T880 is constantly putting hot air though the vent. Even when I have switch on cold, and fan off, the cab gets too hot as there’s a steady flow of hot air coming though.
    Anyone else ran into similar issue or any idea on the issue?
    Thanks
  3. kwcam
    kwcam Light Load Member
    193
    145
    Dec 29, 2012
    at the shop
    Most likely the heater control valve has failed, see if the is a manual valve on the heater hose line that can be turned off will confirm it.
    kestrel1 Thanks this.
  4. JonJon78
    JonJon78 Road Train Member
    7,042
    37,578
    Jul 1, 2018
    Possibly a blend door issue
    kestrel1 and Rideandrepair Thank this.
  5. Brandt
    Brandt Road Train Member
    4,411
    5,949
    Sep 17, 2012
    If your someplace still warm this time of the year. Nothing might be wrong. Their always seems to be some hot coolant flowing thru the heater core. Unless your truck has the manual shut off valves to cut all the coolant flow off you will get hot air at about 68F outside temp I usually find. It only a problem if you a/c is not working and you go south on the winter. That how freightliner is anyway.
    It could be something like others already said if you don't have any control of heat and it's winter.
  6. MRMTRANS
    MRMTRANS Medium Load Member
    334
    372
    Apr 28, 2015
    On my Freightliner C120, I have an electronic water control valve, which shuts the the coolant off from flowing to the heater core when on cold. It is controlled by a cab thermostat, which in turn is controlled by the the temp control dial that has a registered. I don't know about newer KWs, but I bet the system is electronically controlled. In which case, it could be a one of 3 parts that failed, like mine. Mine failed in the thermostat, and it defaulted to heat all of the time.
    kestrel1 and RocketScott Thank this.
  7. MRMTRANS
    334
    372
    Apr 28, 2015
    I meant to say resistor, not registered. Stupid autospell!
  8. LateNightCable
    LateNightCable Light Load Member
    102
    84
    Feb 16, 2018
    I drove a 2016 Kenworth T680 for awhile that had this same issue. Always blew hot air, even with the HVAC ‘off’. I got to driving around in winter, putting the windows down every few minutes to vent the cab.
    The company shop didn’t fix it. I just remember them saying it didn’t throw any codes when hooking it up to diagnostics.
  9. kestrel1
    35
    10
    Jan 1, 2009
    Sacramento, CA
  10. tenishasc
    tenishasc Bobtail Member
    Jan 27, 2022
    Did you press the defrost button, the one all the way to the left? Then it's functioning normally. Try to find a copy of the Owners Manual it's actually explained in there.
  11. goga
    goga Heavy Load Member
    894
    1,586
    Nov 11, 2021
    Earth..
    It's a winter, and I honestly envy you. You've got such a carrying truck, which decided to keep you warm without even your participation.
