Valve stem leakers
Discussion in 'Trucks [ Eighteen Wheelers ]' started by MudBug73, May 2, 2012.
  1. MudBug73
    MudBug73 Bobtail Member
    31
    Feb 5, 2010
    Lafayette, LA
    Sorry if this has been posted, but I have noticed a few of my tires going low. At first glance, it looks to be a valve hole or valve stem issue. I'm going to take them in for inspection but in the meantime, have any of you had any issues with valve stems or valve hole leakers? If so, what was the problem and solution?
    I use steel wheels and haltec stems
    Thanks for your time
  3. last 1
    last 1 Medium Load Member
    439
    184
    Nov 29, 2009
    Try to tighten them sometimes that's all they need
  4. Mark Kling
    Mark Kling Technology Contributor
    10,935
    4,216
    Sep 23, 2007
    Statesville, NC
    Air does expand when you are rolling and contract when it cools down.
    How much are you loosing daily/weekly?
    My jeep shows low air pressure on cold days, but as soon as the tire warms up the sensor is happy.
    Mark
  5. Emulsified
    Emulsified Road Train Member
    3,663
    3,499
    May 6, 2010
    Dallas, TX
    Often it's either the locking nut on the inside isn't tight enough or the rubber grommet on the inside is worn. Either way, it means taking the tire at least half way off the rim to get to it.
  6. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,045
    May 13, 2011
    Middle Tennessee
    Or rust if they've been untouched for a few years.
  7. aiwiron
    aiwiron Road Train Member
    5,927
    5,228
    Aug 24, 2011
    Sunny Tampa Florida
    Tried soapy water yet? Why take it to get inspected until you check it out, it may be something simple you can fix on the spot.
  8. Starline
    Starline Medium Load Member
    357
    251
    Jun 1, 2011
    Middle Tn
    The core has a rubber o ring that does dry out... it could be something as simple as replacing the valve core. I'd try this before the added expense of replacing the valve stem.
    aiwiron Thanks this.
  9. aiwiron
    5,927
    5,228
    Aug 24, 2011
    Sunny Tampa Florida
    I have found keeping the valve stem cap on at any time besides checking the pressure is vital, I have watched DOT write up a driver for no valve stem caps before.
    Sometimes a little dirt will get into the valve stem and cause a slow leak, just saying.
  10. gunner76
    gunner76 Medium Load Member
    500
    137
    Mar 11, 2010
    IA
    The other day when I was drying my wheels after washing the truck I heard a slight hiss coming from the tire, it ended up being a leaky valve stem. I checked all of the tires and had three stems that had slight leaks, I just tightened the core a little more and that cured the problem.
  11. 2bit
    2bit Light Load Member
    178
    39
    Mar 13, 2012
    Medford,WI
    If the core is weak centrifigal force can make them leak going down the road. Always put steel caps on the stem. Or at least send us the video of you hanging off the side checking them with a spray bottle at 60 MPH. LOL
