I’ve got a 2020 Cascadia with approximately 491K miles and it has a DD15. I plan on getting the valves adjusted in a couple of weeks. Has anyone ever done them in 2024 and if so, how much were you charged and how long does it take? Do you also need an oil change with a valve adjustment job?
Valve adjustment cost?
Discussion in 'Freightliner Forum' started by Thunderstorm87, Jul 19, 2024.
id say cost should be between $400-$700, make sure to mention to the shop to adjust injectors and Jakes. Hopefully they’re not bone heads and they include that in valve adjustment, for the time frame I’d say 3-5 hours.rollin coal and Thunderstorm87 Thank this. -
Freightliner did mine for around $400+. I don't have the bill in front of me. I also wanted to say you are changing your oil way to often. These engines are not those old series 60. Have you looked at the required oil change intervals for these engines?. Have you ever done a oil sample for your engine? With that fuel mileage you are getting you are at the high mileage for oil changes. I change mine ever 30k. These engines have longer service intervals now.
Thunderstorm87 Thanks this. -
ibcalm19 and RocketyMan Thank this.
