hey guys. I just need some advice. I have purchase a used international prostar with cummins isx 15. I was just wondering is it ok to like use cruise control when u are loaded like 80,000 lbs and stuff or not.
Please any advice would help.
Thanks
Using the trucks cruise control while loaded?
Discussion in 'Ask An Owner Operator' started by Mandeepsingh, Apr 5, 2019.
Page 1 of 4
Of course.
It will be largely more efficient on flat terrain, so if you're in a hilly/mountainous area of the country you'll wean yourself off of it in those situations because you're constantly dropping gears and having to hit resume. (In a manual tranny I assume).PE_T Thanks this. -
It depends on how the ecm is setup, what did your ecm dump tell you about the settings for the cruise control.
If my cruise doesn't work, the truck is pretty much officially broken until it's fixed. I have an ISX15.
PE_T, Bean Jr., whoopNride and 3 others Thank this.
That's where years of experience will help.
You'll learn your truck.. your operation.. how your lane works most efficiently with your equipment, etc.
Cruise will definitely be the most efficient use of your fuel and equipment on level, easy runs.
If you're a hard charger... a left lane gouger.. pushing the limits all the time.. May as well use the pedal.
If you're willing to stay mostly to the right, and let traffic flow past, where you get to keep your momentum flowing and not a lot of herky jerky on/off left/right lane switching you'll find benefits in the CC.JoeyJunk, pank83, tommymonza and 1 other person Thank this. -
My foot don't like holding the pedal down all day. It also has a hard time maintaining constant speed.
Cruise all day long.JoeyJunk, Bean Jr., tommymonza and 2 others Thank this. -
Some override or cancellation might be called for. Mainly due to traffic density or weather.
CC is PART of the computer decision-making along with gear choice and EB actuation. Your braking tactics and downgrade speed maintenance have sophisticated backup now. New strategies available.
This ain’t 1979 anymore.
Don’t assume. READ the operator manual and make a cheat sheet to tack onto visor.
.Last edited: Apr 5, 2019
Poor boy Thanks this.
Page 1 of 4
