So I recently had my leaf springs replaced on my 2013 Freightliner Cascadia, and I am now noticing that my leaf spring “plates” have shifted a bit sideways (about 1/8 inch or 0.5 cm). Is it a good idea to install clamps to keep the plates as straight as possible? Why don’t leaf springs come with clamps? I see newer Freightliner now have one thick plate on each leaf spring instead of two plates on each leaf spring.
Using Clamps on Leaf Springs (Steer Axle)
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by PE_T, Oct 7, 2018.
Page 1 of 3
By "plates" doe you mean the spacers underneath the leaf spring?
The "U" bolts that are holding the spring to the axle should be retorqued after driving for a while.
This may be why your "plates" shifted.PE_T Thanks this. -
I think he’s talking about the bands that wrap around both leafs that always fall apart when old. I’ve thought about solid brackets but believe they are supposed to be able to give if needed. I wonder if they replaced u bolts should be new reusing old stretched will come loose
PE_T Thanks this. -
I always thought 500 ft lb +. Why were they replaced?
I m thinking of Drive u bolts I just watched a guy torque w/ a tire torque wrench
Rideandrepair Thanks this.
Tighten them with your wheel wrench? I never used a torque wrench when installing springs, just tightened them with a 2' 3/4" drive bar although a torque wrench would be preferred.
PE_T and Rideandrepair Thank this.
Page 1 of 3
