using a lift axle?
Discussion in 'Questions From New Drivers' started by ubart, Apr 29, 2008.
  1. ubart
    ubart Bobtail Member
    Apr 29, 2008
    ottawa
    might be in a 07-08 pay star tri-axle... and not sure how to operate the lift axle? I do know when and when not to use it! HELP!!!!
    snowlauncher Thanks this.
  3. dieselhound
    dieselhound Medium Load Member
    410
    39
    Mar 23, 2008
    Erie,PA
    You only use it loaded. The pressure is something your going to have to play with. For example, If you have brakes on your tag, you may want to put more air air in the bags. That way you don't slide the rubber off. I ALWAYS lift around turns. If it's raining and you don't lift, you may slide straight through the turn. It takes pressure off of your steers. The air pressure I ran was between 30 and 60 lbs. The way I see it, as long as DOT sees your tag axle down, that's good enough.
    FlaSwampRat, snowlauncher and Lepton1 Thank this.
  4. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    You can't over express the need to raise the drop axle when empty if the drop axle is behind your steer. I did it ONCE!! Getting the right pressure on the drop axle will take a scale. That's the way we did it anyway. But we could load the truck to almost the exact weight we needed. The whole purpose of the drop axle behind the steer is to make the steer legal. Some states (I know NV does) will not allow the switch to be located in the cab. So lifting around a corner was not possible for us. Besides, I don't think I'd want an extra 1000 or 1500 lbs added to my steer going around a turn. But I didn't have to worry about cost. And IIRC the pressure was up around 60psi.
    FlaSwampRat and Timmy Fran Thank this.
  5. dieselhound
    410
    39
    Mar 23, 2008
    Erie,PA
    That would suck! Do they allow you to adjust the pressure from the cab?
    FlaSwampRat Thanks this.
  6. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    Nope. Everything was right next to the battery boxes. But we really didn't care since we were always loaded to the max and we needed the distribution of the weight. We just had to remember to lift the axle when empty. Like I said before, I forgot ONCE!!!
  7. dieselhound
    410
    39
    Mar 23, 2008
    Erie,PA
    I lived in Vegas for 5 years so I know it doesn't rain much
  8. Scarecrow03
    Scarecrow03 Road Train Member
    3,411
    7,443
    Sep 27, 2006
    In Your Head
    How did you make turns with the tag down? Was it a steering tag axle like some quads have?
  9. MACK E-6
    48,113
    219,497
    Here, they'll allow the switch in the cab but not the pressure knob.
  10. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    Las Vegas NV does not get much rain and that is a problem. If you've driven a truck there when it just starts to rain then you'll know the streets are like ice with all the oil left on the road. If you leave the drop axle down and you're empty and it just started to rain you will not be able to make the turn. We did not have any control over the drop axle in the cab. Now I don't know if it was because we were hauling gasoline or not but none of the tankers that loaded from Las Vegas had cab control devices. The drop axle right behind the steers did not turn with the steering. They just followed where the truck was turning. If yopu put the truck in reverse the drop axle would raise automatically. If it didn't then it would turn and you'd break some parts.
    You can see the trucks I drove at:
    [Admin Edit: Upload Your Photos Here, No Links To Them, Please]
  11. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    No it just followed where the truck was turned. When you put the truck in reverse the drop axle would automatically raise then when you came out of reverse it would go but down. They had a tie rod that connected both wheels so they tracked the same. I know without the drop axle our steers would be way over. With gasoline we know exactly how much to load since we know the weight of each gallon. And you can bet your bottom dollar that the oil companies get as many gallons as they can and be legal.
    dieselhound I don't know how the rain came into the picture but I will say that the rain is a problem in Las Vegas. And it's for the reason you stated, it doesn't rain that much. But when it does the roads are very slick just like ice. And of course nobody slows down. I've seen more accidents on a day where it just started to rain than any other time including snow storms.
