Used Werner truck- buy or run away?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by gunner76, Jul 11, 2011.
  1. gunner76
    gunner76 Medium Load Member
    500
    137
    Mar 11, 2010
    IA
    I posted this over in the Werner section, but later thought I'd get more responses here since there are more O/O here. I was looking at a couple of used 379's my local dealer got in and found out they are ex Werner trucks. Here is what I found out on one of them. It's an '06 379 with C15@435/1750 with a 13spd and 418k. I ran the engine number through Cat and there were only a couplle of minor claims on the engine: one for an oil leak and one for an oil line. The dealer was closed, but the truck was unlocked so I climbed in to see how the trans shifted, it moved through the gears really smooth without any binding, clutch also felt good. So my questions are:
    1. is the engine able to be turned up by a simple ecm flash to 475-500hp
    2. Will any Cat service center be able to deactivated any of the "nanny" programs that most of these company trucks have? I know Werner has a idle timer and speed is governed to I believe 65.
    3. I've heard that the low mileage Werner trucks that are for sale are wreaked trucks, any truth to this and if so,would a 5yr old truck with 418k be one of these trucks?
    4. How is Werners maintinance program?
    5. Should I just run away since it's one of their trucks?
    The dealer that has the truck has it done up really nice with eight new virgin drives, freshly polished wheel/tanks, and all new brakes. The only downside is the paint is a little faded and I can still make out the Werner graphics on the side, and the top of the hood is a little oxidized.
  3. bigjoel
    bigjoel Road Train Member
    1,573
    1,835
    Jan 20, 2011
    Houston, Tx
    What are they asking for it?
  4. gunner76
    500
    137
    Mar 11, 2010
    IA
    Asking price on their site is $61,500, But I'm sure a guy could get it a little cheaper. Wicks in Omaha has about 30 of these also and they want $71,900 for ones with similar miles.
  5. marek4792
    marek4792 Light Load Member
    62
    31
    Mar 21, 2011
    Chicago, IL
    they're good trucks but if it's mechanically fit i wouldn't worry but, however i would check if it had history of major cosmetic damage/ frame damage. my dad had drove an ex werner 02 century (detroit 60 w/super 10) and the cab had a very visible lean to one side and did not sit even on the frame, but everything was working like its suppose to. i think they need to cut the price in half tho, that is too high regardless if its a pete or shaker
  6. gunner76
    500
    137
    Mar 11, 2010
    IA
    I checked the truck over pretty good and it doesn't appear to have any body work done to it. The truck sat normal, frame looked straight and the paint matched over the entire body(other than where the decals were). The frame also appeared to have original paint on it and had a normal amount of rust starting to show up for a truck that has been on the road for 5yrs.
  7. marek4792
    62
    31
    Mar 21, 2011
    Chicago, IL
    well sounds like a good truck in your case, if you are really interested in it, i would start knocking the price down, i saw ex werner shakers on tp with a half mil. miles running condition for $30k you should be able to pick up a pete in that condition for around that price, but seems like the other $30k is just the name.
  8. rollin coal
    rollin coal Road Train Member
    13,083
    25,871
    Mar 29, 2008
    TN
    I was talking with my local cat dealer when they ran the overhead about ecm flashing. The manager told me that from corporate orders they can no longer set the governed speed any higher on road trucks than 70 mph due to liability. Not that I would ever trust them to mess with my ecm we were just talking...
  9. melpromud
    melpromud Medium Load Member
    463
    114
    Jan 29, 2010
    camden ny
    As far as the "wrecked" thing you dont want to buy a 2009 or 2010 with 100,000 miles. Why would they get rid of it if it wasn't a wreck the was patched together. 4 or 5 years old with 400k its being sold because its time to upgrade. Just remember at 700k to 800k this truck will need a 20+k overhaul. Thats only 3 years of running and you will most likly still have a payment on it. If it were me 350k is about the max milage I would buy on a used truck. That way its hopefully paid for when the major components need replacing or rebuilding. With that said I have herd good things about ex Werner trucks.
    Jay klinker Thanks this.
  10. gunner76
    500
    137
    Mar 11, 2010
    IA
    I kinda figured this truck would be exempt from the wreaked/rebuilt group but just wanted to make sure. I actually have enough to pay for the truck, but will probably put it on a three year loan so as not to deplete my excess funds just in case I would run into problems. If there is no big problems after a year I will probably pay the truck off.
    I know alot of people that run Cat's and they all say to be prepaired to do an OH around 700-800k. I'm still looking for a lower mileage truck to show up, but finding one spec'd like I want and pre DPF is getting harder.
  11. marmonman
    marmonman Road Train Member
    1,417
    2,842
    Dec 14, 2009
    central illinois
    I have never rebuilt a cat with less than a million miles on it. I bought this truck I am in now with 465000 on it and I dropped a reman engine it at 1.3 million.
    I guess it is just how you take care of it and if you get a good one . I must be real lucky I haven't got a bad one in the last 30 years !
    Jay klinker and azcardnlz Thank this.
