Used flatbed combo vs all aluminum
Discussion in 'Ask An Owner Operator' started by Codycodycody11158, Dec 29, 2021.
  1. Codycodycody11158
    Codycodycody11158 Bobtail Member
    46
    46
    Oct 27, 2020
    Hello folks! Just trying to get feedback on an upcoming used flatbed I’m purchasing. It’s a 2003 all aluminum chaparral trailer. Seems like it’s in great condition. The guy selling it seems honest. Im going to check it out in person this weekend. My dad is saying that’s a horrible idea and all aluminum trailers crack. What is everyone’s opinion on this?
  3. ProfessionalNoticer
    2,941
    7,852
    Apr 25, 2021
    What is it rated for and what do you plan to haul with it? Your trailer should match the freight you want to put on it.
    feldsforever and shooter19802003 Thank this.
  4. abyliks
    abyliks Road Train Member
    3,747
    8,695
    May 2, 2010
    ludlow MA
    Check all the welds, usually when someone spec’s something light like that, it’s for a reason…
    Vampire and 77fib77 Thank this.
  5. shooter19802003
    5,654
    42,106
    Feb 8, 2010
    I would say that all aluminum flats are more common now than combos are. Just check for cracks around the landing gear and suspension. Also check the arch. Beyond that, pretty simple. Good luck.
  6. Codycodycody11158
    46
    46
    Oct 27, 2020
    I appreciate the feedback fellas!
    Vampire and feldsforever Thank this.
  7. kwswan
    kwswan Road Train Member
    1,900
    9,845
    Jul 26, 2009
    mcminnville,tn.
    I don't have any experience with a Chaparral flat but I hope they are built better than their livestock trailers were. When they were building those in the early part of the 2000's I knew a fellow who bought one & after a couple of years the floors started coming up in it. Come to find out they used some sort of glue/ adhesive to fasten the floors instead of welding like a Wilson.
  8. Crabbypatty
    Crabbypatty Bobtail Member
    12
    14
    Dec 21, 2021
    I've owned a few of both. Pull a bunch of different ones every week that I don't own. I owned a Benson all aluminum and a fruehaufe combo with steel beams aluminum crossmembers and bed, some combos have steel crossmembers and are heavier. The Benson was stronger but was rated higher to begin with it was lighter by about 1500 lbs. As far as cracking I've seen it more in combos especially transcraft. Pay close attention around the spring hangers. You don't have to worry about rust on all aluminum so that's a plus. Having said that I pull a 53ft transcraft sometimes for the company I work for and it's a good trailer. I pull a couple of routiniers and Fontaine phantoms too. The fontaines are my favorites and I pull alot of different trailers ranging from all steel tandems to 53ft spread axle combos and everything in between. If I were buying a trailer for myself it would definitely be all aluminum and probably be a Benson, fontaine,east or Mac. Hope this helps.
  9. Crabbypatty
    12
    14
    Dec 21, 2021
    Oh yea if your going to only pull the one trailer get a dump valve, I had one on my Benson and it helps getting it in places and helps keep the binding to a minimum when your twisting it around.
    Speed_Drums and shooter19802003 Thank this.
