USED APU worth it for a used truck?
Discussion in 'Ask An Owner Operator' started by speedstickman, Feb 23, 2024.
  1. speedstickman
    speedstickman Light Load Member
    66
    20
    Jul 10, 2012
    Is it worth getting a used APU for a used truck that has 600k miles on it? Or should I just let the truck idle till it dies... are used apus a headeache? looking into gogreen apus specifically...
    77fib77 Thanks this.
  3. flood
    flood Road Train Member
    4,157
    4,020
    Dec 25, 2010
    3,500w Portable super quiet generator $1,000
    Portable ac $300 or mini split ac/heat pump $700...
    Generator and portable ac install time under 1hr in your driveway.
    Generator full replacement warranty 2 years
    Ac full replacement warranty 1 year
    Fuel used per 12hr 2gl... $6-$7
    rokue, BlackThought, Opus and 2 others Thank this.
  4. speedstickman
    66
    20
    Jul 10, 2012
    How do you install it?
  5. Concorde
    Concorde Road Train Member
    4,344
    15,421
    Jun 29, 2016
    West Melbourne Florida
    Save your money for an in-frame…it’s getting near that time.
    Siinman and 77fib77 Thank this.
  6. special-k
    special-k Road Train Member
    1,523
    3,258
    Dec 27, 2008
    Southern Ontario Canada
    Depends on where your running and how long your out for. I see all these guys justifying a genset by saying they're running it 365 days a year. Nobody needs a genset that much. And l agree with Concorde about saving some money for an in frame...
    wifi_guru, Siinman and Concorde Thank this.
  7. wifi_guru
    wifi_guru Medium Load Member
    352
    317
    Feb 22, 2024
    Buy a genset and a portable ac unit.
    Cummins makes a 4500 watt inverter genny for 1,200 on Amazon a poor man's honda
    Champion has one to same wattage I think it's 100.00 cheaper reliability I have no idea about though I would go for the Cummins over the Champion. I have always bought Hondas they just keep working look into getting a gentent also. And a space heater for winter and a 10 Guage extension cord to handle the load. And get a carbon monoxide detector if you don't have one
    flood Thanks this.
  8. flood
    4,157
    4,020
    Dec 25, 2010
    Mount generator on catwalk with ratchet straps and cable or chain locks.
    Heavy-duty extension cord thru per existing hole in floor.
    AC (think R2D2) strapped to the side of passenger seat
    wifi_guru Thanks this.
  9. wifi_guru
    352
    317
    Feb 22, 2024
    Save the money for an inframe and overhaul your gonna need one soon. A decent inverter genny is more quiet than any apu I ever heard. I heard with the tripacs they have a hard time keeping up in 102 degrees and they over heat and shut down and drivers have go outside and open the door
    Vampire Thanks this.
  10. wifi_guru
    352
    317
    Feb 22, 2024
    How much is this used apu brand is it i have a guy in ok that will install a new tripac for 14k . Also talk to people that own em I hear when they break there not a cheap fix
  11. wifi_guru
    352
    317
    Feb 22, 2024
    And get an extension pipe for the exhaust
