Scheduled for orientation. What is the road test and backing test like? Been out of trucking for about a year and a half. Not really worried about the road test, but my backing may be a little rusty. Is it still policy that if you fail backing they will send you out with a trainer for two weeks and not automatically send you home? Also, whats the motel like in West Memphis. What kind of food do they give you there? Only breakfast and lunch or all three?
Looking forward to getting back in a drivers seat. I was out of trucking because of a blood pressure issue and was miserable not being on the road. Also, what kind of equipment are they assigning now-a-days?
USA truck orientation and road test in West Memphis
Discussion in 'USA Truck' started by VolunteerTrucker, Mar 26, 2018.
VolunteerTrucker Thanks this.
Road test is easy , a couple of tight turns and they give you a lot of time to back . West Memphis is probably gonna be one of the ones next to terminal, you will more than likely have a roommate unless you pay the upgrade fee and I'm sure glad I did . I found a cheap flight out there screw the Greyhound. Good luck out there!
You should do good at backing. Its still a piece of cake my brother go for the goal
Yea if you fail backing test they send u out with trainer 1-2 wks ..road test not that bad just couple left and right turns couple miles on highway the guy does road test is lay back relax kind of guy down earth they give you 15min on backing. If you hav smart phone go under goole maps with satellite ur see two trailers with blue barrells that where u back in at. I did a 45 n got right in there other then that there nothing to wrry about your.ll be fine
They were passing guys who barely knew how to drive , I guess they figure you will learn with your trainer.
