us steel safety question's
Discussion in 'Flatbed Trucking Forum' started by heavy6405, Apr 17, 2012.
  1. heavy6405
    heavy6405 Bobtail Member
    Doe's anyone know if there's a cheat sheet for the safety question's on the computer at US Steel mill's to pic a load?
  3. Semi Crazy
    Semi Crazy Road Train Member
    3,033
    2,044
    May 13, 2011
    Middle Tennessee
    It's all in the fed's cargo securement regs which are online.
    Mommas_money_maker Thanks this.
  4. Gentlemanfarmer
    Gentlemanfarmer Medium Load Member
    365
    384
    Feb 26, 2010
    Greenville, FL
    1. Have you been trained in coil securement? YES
    2. Do you cross chains on suicide loaded coils? NO
    3. Is speed limit inside plant 30 mph? NO
    4. Are all chains rated at 10000 lbs? NO
    5. Is it ok to let coil touch floor of trailer? NO
    6. Are rubber mats required to load? YES
    7. Are you required to personally inspect equipment? YES
    8. Are you allowed to stand on trailer while loading? NO
    9. Are you required to have hard hat, glasses and sleeves inside plant? YES
    10. When loaded en route should you check load within 50 miles? YES
    11. Is it your responsibility to tell shipper where to put coils? YES
    12. Shoud the coil be suspended from trailer deck with racks, boards and mats? YES
    13. Are you allowed to stop on railroad tracks? NO
    14. Must you put a chain or strap over top of a shotgun loaded coil? YES
    15. When you pass the guard shack, is the speed limit 35 mph? NO
  5. bucksandducks
    bucksandducks Medium Load Member
    656
    538
    Mar 29, 2007
    WI
    If someone needs a "cheat sheet" to answer these ?'s they have no business hauling a coil. They probably don't have enough common sense to drive a truck either. The only one that isn't common sense is #2.
    Fatboy42, ChevyCam, TripleSix and 5 others Thank this.
  6. Mommas_money_maker
    Mommas_money_maker Road Train Member
    1,122
    765
    Oct 2, 2011
    North Carolina
    I was seriously thinking the same thing.
    Tug Toy Thanks this.
  7. plentygood
    plentygood Road Train Member
    1,108
    729
    Apr 24, 2011
    USA / CANADA
    Yup! :thumbup:
  8. AZS
    AZS Honk if anything falls off
    2,912
    1,303
    Sep 30, 2010
    PHX, AZ
    Hey he only has 35 years experience, cut the guy some slack lol.
  9. The Admiral
    The Admiral Heavy Load Member
    894
    561
    Jul 18, 2010
    Akron,Ohio
    Amazing isn't it the Mills expect more and more but want to pay less and less. Isn't deregulation great!
    D.Tibbitt, passingthru69 and Hardlyevr Thank this.
  10. Willy2000
    Willy2000 Bobtail Member
    Doe's anyone know if there's a cheat sheet for the safety question's on the computer at US Steel to pick a load? now the test is different I see this one but is very old,question are different the way to secure de coils
  11. D.Tibbitt
    141,126
    dude those questions are so easy. why do u need a cheat sheet. i passed on my first , i had to think about the questions because they are the type of questions they are so dumb, u have to dumb ur brain down a few IQ points to understand the stupidity
    Lepton1 and JonJon78 Thank this.
