UPGRADING 2021 x-15 air compressor?
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Rolling18, Nov 30, 2020.
  1. Rolling18
    Rolling18 Light Load Member
    170
    34
    Dec 11, 2008
    Portland, OR
    I have a 2021 brand new T880 dump w x-15 "productivity" 565 @1850 tq..
    2 drop axles, air suspension, lift. so there is LOTS of air being used compressor barley keep up.
    has the smallest @ about 18 cfm. and take forever to till all the tanks./ airbags
    We want to "upgrade" already to the 2 cyl. 34ish cfm compressor.
    Found a great deal on the 2 cyl unit and only need a few smaller support items
    SUPPORT, AIR COMPRESSOR
    CAP SCREW, HEX FLANGE HEAD
    SCREW, HEX FLANGE HEAD UNKNOWN
    ELBOW, MALE UNION
    is this as "simple " as swapping the parts,
    what all is involved?
    time estimate?
    THANKS!!
  3. BoxCarKidd
    BoxCarKidd Road Train Member
    4,418
    6,431
    Aug 26, 2014
    Never did exactly that but many compressors are very interchangeable. As long as the supplier has the correct mounting flange and drive. Does yours also drive something off the back like a P/S pump? That also must have the correct mounting.
    Normal compressor replacement would be under 4 hours. Mr Wiz might get ur done in 2. Your coolant and air connections will be different. Hope to finish it in a day.
  4. magoo68
    magoo68 Road Train Member
    3,393
    5,385
    Jun 11, 2011
    st malo mb canada
    Being the-productivity version it may be controlled by ecm for fuel savings . If so maybe dealer can reprogram it better for your application .it doesn’t hurt to ask.
    BoxCarKidd Thanks this.
  5. BoxCarKidd
    4,418
    6,431
    Aug 26, 2014
    Wow! Never even knew some compressor operation could be ECM connected.
  6. Concorde
    Concorde Road Train Member
    4,345
    15,431
    Jun 29, 2016
    West Melbourne Florida
    I have a 2021 with same engine and specs..Mine came with the “Heavy duty” compressor. All I can say is, it’s impressive.
    Sadly, the upgrade is only $100...
    Try bringing it back to the dealership and see if they can pull some strings for you to have it swapped out...that’s where I’d start.
    magoo68 and spsauerland Thank this.
  7. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    Cummins air compressor isnt ecm controlled.
    The most I have seen for air compressor ecm interaction is on the MX13 epa 17, when the air compressor starts pumping the water pump goes into full speed.
    Talk to the dealer you bought it from and they should be able to look up the larger air compressor option and let you know all the parts required. Different support brackets on the larger compressors and different plumbing.
  8. dclerici1
    dclerici1 Medium Load Member
    525
    1,582
    Aug 1, 2012
    MISSOURI
    Did you order the truck or was the truck ordered by the dealer and you bought it “ off the lot”? Were the lift axles factory installed or dealer installed?
    Either way I’d say the dealer screwed up and you should get them to help pay for the modification.
    If you worked with a salesperson to spec/order, or if the dealer ordered the truck as a “stock” truck they should have been experienced enough to know the application that the truck was headed for and they obviously were’nt. They sold you a truck that is unsafe on the road.
    The dealer needs to work with you on a satisfactory outcome.
    Roberts450 Thanks this.
  9. spsauerland
    spsauerland Road Train Member
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    If you watch any Peterbilt Steve videos that @Cat sdp posts, Steve specs most all of his X15's with the larger CFM air compressors.
  10. Rolling18
    170
    34
    Dec 11, 2008
    Portland, OR
    thanks for all your fast responses....
    The dealer told me that I CANNOT UPGRADE the compressor as it is "specific" to the engine.
  11. spsauerland
    4,296
    10,886
    May 31, 2010
    West Harrison, In
    pushbroom Thanks this.
