Unusual wear pattern ruining trailer tires
Discussion in 'Ask An Owner Operator' started by RunningAces, May 14, 2024.
  1. RunningAces
    RunningAces Road Train Member
    1,263
    2,513
    Jul 2, 2017
    Two tires in a row wore in this weird wave pattern. It's an Inside tire on the front axle of a 48 ft spread. Shocks were changed about six months ago. I drive at about 68 mph loaded or empty if it matters.
    Edit: forgot to mention both tires are equally aired on the duals.
  3. OlegMel
    OlegMel Medium Load Member
    370
    633
    Apr 8, 2023
    Wheel bearings loose most likely. Get them torqued down and regressed. I had the same issue. Jacked up the axle, took of the cover and I could unscrew the axle nut by hand.
    shatteredsquare and RunningAces Thank this.
  4. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Hendrickson light weight axle flexes under load. Wheel ends of the axle bend upwards while flexing down the road causing inner tire to wear.
  5. RunningAces
    1,263
    2,513
    Jul 2, 2017
    What do I do to stop it from happening in the future?
  6. lester
    2,914
    7,842
    Jan 2, 2012
    NW, Iowa
    take it to a good alignment shop.. they can bend some positive camber into the axle to account for loaded flex
  7. rollin coal
    rollin coal Road Train Member
    13,083
    25,876
    Mar 29, 2008
    TN
    Weld some angle iron across the top and bottom of the axle to stiffin it up.
    Otr Traveler, Vampire and Siinman Thank this.
  8. Long FLD
    Long FLD Road Train Member
    11,375
    45,873
    Mar 4, 2015
    MD Alignment recommends the angle iron trick to stop axle flex.
  9. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    Alignments and wheel bearing tightness should be checked occasionally
  10. abyliks
    abyliks Road Train Member
    3,746
    8,694
    May 2, 2010
    ludlow MA
    What brand rubber?
  11. uncleal13
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Axle flex and tire wear
    Some discussion about it here, some had success with getting chamber bent into the axle at a good alignment shop.
    lester Thanks this.
