Uniden Bearcat 880
Discussion in 'CB Radio Forum' started by TheBigCooler, Sep 11, 2014.
  1. TheBigCooler
    TheBigCooler Bobtail Member
    11
    Aurora, Nebraska
    I was curious if anyone has experience with the Uniden Bearcat 880. I've seen videos on youtube from cb shops doing a walk-through, and have done a ton of research. I'm about 95 percent sold on one as I'm a techie and love the modern technology. What do you guys think about this radio?
  3. BigJim63
    BigJim63 Light Load Member
    57
    56
    May 1, 2014
    Evansville In.
    I got one of these radios last year with Pilot points. I like this radio, it is not an audio powerhouse but I think it gets out and receives as well as my Uniden pc68 and i get good audio reports from other drivers. The best thing is to get a good antenna and coax to make this radio perform the best it can.
    TheBigCooler Thanks this.
  4. Phantom409
    Phantom409 Bobtail Member
    34
    8
    Sep 21, 2011
    Manchester, Tn
    Sure hope it last longer than my Uniden PC-68 Elite. Purchased in the middle of July, 2014 installed, tuned and was the best working CB I ever had. Last one was a Galaxy 959. it only lasted a few weeks also. The Uniden was loud, strong, clear with the Hustler antenna system. Finally though I had found a good one. 6 weeks later, no modulation, no dead key swing, no xmit...... Rec's great. Another $100 down the drain. Thinking of switching to the MURS fm system, but there are not alot of people using them...
    Best of luck with the Bearcat...
  5. MsJamie
    MsJamie Road Train Member
    I have a 980, which is the sideband version, and I love it. Don't expect it to do 50W and 200 channels, though. Just get your mic gain set up (with a good mic), and it will sound really good.
    If you feel you just have to have more power, go outboard.
  6. Big_m
    Big_m Heavy Load Member
    881
    265
    Oct 13, 2009
    Central Maryland
    For those 2 radios to die in such short time tells me that something else is your problem. Like your antenna system may have a high SWR. Are you running an amp with a peaked radio?
    mike5511 Thanks this.
  7. MsJamie
    The downside of doing a "tweak and peak" to your radio... you burn out the finals.
    The output transistor on these radios is designed for 5 Watts. Yes, it's possible to drive it harder, and it will output more than 5W, but such operation will kill it.
    A friend of mine had a 6 cell MagLite, and stuck a bulb for a 5 cell in it. Yes, it was insanely bright. It didn't last very long, though.
  8. Pool6710
    Pool6710 Medium Load Member
    662
    258
    Aug 10, 2014
    Minnesnowta
    I tried to add a 700wt amp to a bc880 and the amp is no longer working. The radio works great still and I get amazing reach and talking ability. I have the weather band warning system activated so it's nice when you know severe weather is in the area. I just wish this didn't fry my amp and I have no idea who or what would fix it.
  9. JPenn
    JPenn Road Train Member
    1,829
    1,873
    Mar 5, 2008
    Northern Tier PA
    I had the 980. Really nice radio, to run at stock levels. Very finicky about antennas though...mine would not work through factory coax and a friend and I tried it on 3 different trucks. A 25' coax to a Wilson 2000 worked wonderfully. Never did push it, or use it to drive an amp, though.
  10. ShooterK2
    ShooterK2 Road Train Member
    5,533
    89,470
    Dec 14, 2012
    Oklahoma
    I have the 980 also. I love this radio. I've had a lot of "big" radios before (still own a few), but I use my 980 exclusively now. If you're into seeing big numbers on the power meter, this may not be the best radio for you. I learned a long time ago that those numbers have very little to do with the actual performance of a radio in the real world anyway. However, I do like the "big radio" sound, so I bought a RF Limited 2018 noise cancelling power mic for it. I've heard it on the receiving end (taken recordings with my phone so I could set the mic correctly), and it sounds just like some of the most expensive exports out there. With a good antenna and good coax, it really gets out. I've also talked on 38lsb from Oklahoma/Texas to most states along the east coast and New England. No amp required or used.
