uneven brake shoe wear
Discussion in 'Trucks [ Eighteen Wheelers ]' started by rollin coal, May 1, 2010.
  1. rollin coal
    rollin coal Road Train Member
    13,083
    25,858
    Mar 29, 2008
    TN
    On my drive axles the bottom shoes look like they're wearing down twice as quickly as the top ones. What's causing that? Also I can hear and somewhat feel when bobtailing what sounds like the rear left side brake dragging slightly. Is there something worn out or needing adjustment?
    x1Heavy and JustSonny Thank this.
  3. C16KIWI
    C16KIWI Medium Load Member
    575
    142
    Jun 14, 2008
    New Zealand
    I had much the same problem and it turned out to be a wheel bearing not adjusted right.
  4. stranger
    stranger Road Train Member
    3,640
    4,959
    Oct 10, 2006
    NC
    The brake return springs are probably weak. The lower one always has weight on it, so it weakens first, letting the shoe hang just a little. When changing brake shoes, always use new springs. They will pay for themselves with decreased shoe wear.
    Also, check your S-cam bushings. If they are worn, the shaft will push sideways when the brakes are applied, and one shoe will press harder than the other.
    It wouldn't hurt to check wheel bearings as stated above.
    Rideandrepair, x1Heavy and JustSonny Thank this.
  5. rollin coal
    13,083
    25,858
    Mar 29, 2008
    TN
  6. 112racing
    112racing Road Train Member
    1,384
    20,548
    Nov 30, 2008
    pocono's, pa
    s cams and bushings worn allow the cam to move up and down so it will push on one shoe harder than the other
    JustSonny Thanks this.
  7. Superhauler
    Superhauler TEACHER OF MEN
    12,209
    100,727
    Jan 30, 2010
    keep stroking.
    yea what they said the pins that hold the shoes in place could also be worn
  8. lastgoodusername
    lastgoodusername Medium Load Member
    444
    215
    Dec 18, 2008
    central NC
    agree with all the above.
    1. pins or their bushings
    2.s cam and it's bushings
    3. i've never had a weak spring, but i have had a broken spring
    4. wheel bearings
    5. bad shoe backing plate
  9. rollin coal
    13,083
    25,858
    Mar 29, 2008
    TN
    A friend of mine told me to jack up each wheel on the rear axles one at a time and get a pry bar or something under there to pry with to see if there was any play in the wheels. If not the wheel bearings are fine. I did that and they look fine there is no slop. Does that sound right on checking wheel bearings?
  10. stranger
    3,640
    4,959
    Oct 10, 2006
    NC
    Jack up the rear wheels, put a long pry bar in one of the wheel holes, then try to pick up on the wheel. Any play will show up that way.
  11. JohnP3
    JohnP3 Road Train Member
    1,594
    683
    Feb 21, 2010
    Rock Creek B.C. Canada
    Stranger is right on the wheel bearing inspection, if the bearing was loose enough to wear the brake shoe uneven it would have leaked all the oil out and fallen off. With the brakes backed off you can put a screw driver under the bottom shoe and if both the shoes move up and down the "S" cam and bushings are worn, and you have to pull the wheel and change them. Being cheap and thinking you are saving money by not repairing worn brake parts, is not a good thing. That bottom shoe that is worn down, wore out while you were on the throttle. The second set of brakes you may get away with not changing the "S" cam and bushings, if you rotate the "S" cam 180 degrees and have kept the thing greased. Grease is the cheapest repair you will not need. Just a thought!
    Rideandrepair and stranger Thank this.
