Understanding the Mechanics of Shifting
Discussion in 'Questions From New Drivers' started by Trukker_1736, Feb 13, 2020.
  1. Trukker_1736
    Trukker_1736 Bobtail Member
    4
    Feb 12, 2020
    I've had my license for a few years now but I don't have a lot of experience. I've gotten a lot better but when I first started out I was probably the worst shifter ever. I don't have a mechanical background and the Eaton Fuller 18 speed was the first thing (out of anything) that I learned on.
    I'm currently driving for an oilfield company. Up until now I really didn't care much about the Mechanics going on under the hood. As long as I could shift into the next gear with as little grinding as possible I was happy
    Recently, I've become more interested in what's actually happening under the hood and possibly becoming a better shifter and ultimately driver. But I'm not sure if my current understanding is correct, hence this post.
    I want to preface the following by saying that I'm looking for just the basic intuition and concepts here. I realize that I'm leaving a mountain of info out. If the exclusion of some piece of information is resulting in my misunderstanding please let me know.
    Okay, so I've never really understood the mechanical reason for shifting and needing to shift certain gears at certain engine rpms and road speeds.
    This is how I currently understand the process: you've got the input shaft which is connected to and spun by the engine (skipping over the clutch for now). On the end of the input shaft is a gear. This gear is in mesh with a gear on the countershaft of the transmission. The countershaft also has all of the other gears. These gears are in mesh with the gears on the output shaft.
    The key point is that the gears are all different sizes. The 1st gear on the countershaft is small in diameter compared to the gear it is in mesh with on the ouptut shaft. So at a given engine rpm the smaller on the countershaft will have more revolutions than the larger gear it is driving. I should have mentioned that the gears on the output shaft are spinning freely of the shaft itself. There is another gear, the hub, which is connected to the output shaft. When shifting into the gear (let's say 1st) a sleeve connects the hub gear with the big first gear on the output shaft (again oversimplifying here). The big first gear is now driving the output shaft and it in turn is being driven by the smaller gear on the countershaft which is being driven by the engine.
    Given that the output shaft big gear is being driven by the smaller countershaft gear we have lots of torque and this is what we need in the low gears to get the truck moving. The larger the radius of the gear the more torque we will have. But a larger radius means that the gear is not completing as many revolutions as a smaller gear would in the same amount of time. Therefore the truck has lots of torque but not a lot of speed.
    Okay this comes to sort of the crux of my question. The truck is moving, but slowly because of the low rotational speed of the big gear. We want to go faster, but the big gear can only spin so fast. And so when we give the truck more gas increasing the engine rpms the truck does not speed up in direct proportion to the engine rpms because the smaller gear on the countershaft can only spin the big output shaft gear so fast. This may sound a little weird but there is diminishing returns on the speed of the output shaft given increasing speed (rpms) of the countershaft.
    We need the truck to go faster. Given we already have forward momentum, we don't need as much torque as when the truck first started off. We need to trade speed for torque. We accomplish this by shifting to a larger gear on the countershaft that drives a smaller gear on the output shaft. A smaller gear on the output shaft means less torque but more rpms which results in a higher road speed.
    If I'm double clutching is this why you increase the rpms let's say to 1600 (just as an example), shift into neutral, and then shift into the next highest gear at say 1200 rpms? We need to sync up the speeds of the lower larger gear and the higher smaller gear. So we get the larger gear spinning at the top of the rpms range and shift into the smaller gear at the bottom of the rpms range because this range basically compensates for different rotational speeds of the two gears?
    And conversely when you are downshifting. Before downshifting, the gear you are in is in some way proportional to the road speed. The next lowest gear obviously has a bigger radius and thus is not turning as fast. So you brake a bit and let your rpms drop to the low range (again say 1200). This is going to slow the rotational speed of the gear you are in down. You shift into neutral. But the smaller gear that you just shifted out of is probably still rotating faster than the larger gear you are trying to shift into. To compensate for this we press the gas to increase the engine rpms. This spins the larger gear faster which helps to sync up with the faster rpms and road speed that the output shaft was just previously in.
    I realize this question is extremely long but I'm hoping someone can see what I'm trying to ask here. Basically, where we set our engine rpms when shifting (up or down) is a result of trying to match up the rotational speed of the next gear with that of the output shaft. If I'm way off here can someone explain to me where I've gone wrong?
    Thanks
    Rideandrepair Thanks this.
  3. truckdriver31
    6,989
    8,352
    Sep 18, 2013
    its the clutch gates open at different rpms. you can do a pick up the same way
  4. ibcalm19
    ibcalm19 Road Train Member
    1,463
    2,435
    Nov 30, 2015
    Pennsylvania
    Modern technology(YouTube) saves a thousand paragraphs :D:D
  5. HoneyBadger67
    2,056
    4,511
    Dec 15, 2018
    Savannah, TN
    Would I oversimplify if I just said...
    "I was told to over rev a couple hundred and slide out of gear when my foot was coming off the throttle and ease back (forward) into the next gear on the upshift. To downshift, just reverse the process but 'blip' the throttle to raise the R's. Don't worry, mate, grind 'em til you can find 'em."
    I've always been taught by men and men ain't keen on lots of 'splainin'. "Learn by watchin', boy, I ain't here to hold yer hand!" (Trying to teach the wife in this manner causes all sorts of consternation)
    jammer910Z and Rideandrepair Thank this.
  6. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,129
    Mar 5, 2016
    White County, Arkansas
    A tractor trailer is non syncronized. It is not a car.
    YOU are the syncronizer. A given engine in a 18 wheeler will have steps of 400 RPM between torque and high horse power and the sweet spot will be somewhere in the middle. Example 1250 to 1650 RPM. You will find you can shift every gear at those two RPM's without grinding and without the clutch once you get moving. (First things first...)
    Don;t rush a manual shift. Wait about two heartbeats. Then you get into the groove. Clicaclick! Up or down.
    Some of the older trucks dating to about the late 70's would wind all the way to about 2000 then shift up and be within about 300 or so RPM way up there on the tach. Lots of fun. The main thinking by engine makers in big rigs is to have the engines run slower to save fuel at cruise speed limit.
  7. AModelCat
    154,529
    Shift by tach. Road speed is irrelevant.
    Basically, condensed down, all shifting is just matching mainshaft speed to mainshaft gear speed.
  8. D.Tibbitt
    141,109
    Its not a truck tranny but this shows u the basics of how tranny works
  9. CaliTrucker1982
    CaliTrucker1982 Bobtail Member
    9
    Feb 13, 2020
    California
    Does every truck have clutch brakes?
  10. x1Heavy
    34,017
    42,129
    Mar 5, 2016
    Kinda. They are supposed to generally.
    The thing is this. You only engage clutch brake when stopped or getting ready to come off parking brakes to get a gear. You do NOT engage the thing by shoving too deep on the clutch pedal. It hurts it. Just enough to break power to get the shift.
  11. Rideandrepair
    17,215
    55,893
    Aug 8, 2015
    Learn to float the gears,without double clutching, watch the tach, listen, shift by ear. Studying it and getting a feel for it. Then it all makes sense. The actual workings of the gears can be found on Eaton’s website. The engine has its rpm range,can only do so much, the rear axle turns at the same ratio always, the trans makes the two work together, in harmony, like sweet music,Lol
    D.Tibbitt and x1Heavy Thank this.
