Under CDL dump truck jobs
Discussion in 'Tanker, Bulk and Dump Trucking Forum' started by Ddr1992 579, Oct 20, 2021.
  1. Ddr1992 579
    Ddr1992 579 Medium Load Member
    395
    100
    Sep 10, 2018
    Is it possible to find a job involving driving dump trucks that don't require a CDL license? I would like to have some idea on the type of work that does this type of work... That's the type of work that I would like to do if possible... Any help will be appreciated
  3. RoadSideDown
    RoadSideDown Light Load Member
    163
    343
    Feb 26, 2021
    Any dump truck on a public road will require a Class B CDL, and if it tows a trailer you need Class A.
    You can drive mining dump trucks without a CDL because they usually operate only on private land. 40-400 ton payloads!
  4. Ddr1992 579
    395
    100
    Sep 10, 2018
    Even medium duty, single axle 6 wheel dump trucks? Something like an f650 or gm medium duty (Kodiak/topkick)? Most of them aren't CDL weight trucks...
  5. RoadSideDown
    163
    343
    Feb 26, 2021
    You won’t be hauling much material with a 25,000 lb gvw limit. There might be a use for such a small dump truck but there will be very few jobs for it. Probably best bet is with landscapers. Non CDL drivers usually make under $20/hr.
    brian991219 Thanks this.
  6. Ddr1992 579
    395
    100
    Sep 10, 2018
    if there's landscaping companies that uses medium duty single axle dump trucks and pulls equipment, when I get into the position to get a landscaping job, I'll remember that you helped me... And make sure that the moderators or bosses on this site know that you assisted me... Thanks
  7. 201
    201 Road Train Member
    12,042
    24,575
    Apr 16, 2014
    high plains colorado
    While many landscaping and construction firms do use light duty dump trucks, usually the job involves operating machinery that you may not be used to. The dump truck is just a sideline to the job, and not many places hire someone to just drive the little dump truck. While the machinery experience is useful, not many places will take the time to teach you. I say, just get the CDL, then you can run with the big boys,,,and riches beyond your wildest dreams,,:rolleyes:
    RoadSideDown Thanks this.
  8. REO6205
    REO6205 Road Train Member
    13,172
    60,482
    Feb 15, 2014
    California.
    Tequila?
  9. TNSquire
    TNSquire Medium Load Member
    555
    1,913
    Oct 13, 2016
    Decatur, TN
    Single axle dump trucks are heavy, relatively speaking.
    You can load about 5 ton and stay under 26k.
    Tri axle dumps can load 20 to 22 ton.
    Big difference between the two.
    Given that anyone can operate one without a cdl, the money for that work drops like a hooker's panties.
    So, to get into that, knowledge of equipment, specifically skid steer, mini excavator, trencher, Toro dingo, etc... is needed.
    The guys I know that are in that business pay well for operators.
    17 to 20 an hour.
    The bulk of the work is on the ground, not driving.
    Larger companies run tri axle dumps for efficiency.
    Smaller ones run junk equipment because they're scraping by on smaller jobs that don't pay.
  10. Ddr1992 579
    395
    100
    Sep 10, 2018
    Mostly not anymore... I've had my name changed... I've been doing a little bit more research and I'm discovering quite a bit more than I used to
    REO6205 Thanks this.
