Under cab and sleeper lights question.
Discussion in 'Peterbilt Forum' started by Auctioneer, Jan 31, 2019.
  1. Auctioneer
    Auctioneer Light Load Member
    72
    38
    May 7, 2010
    Trenton, NC
    I have a recently purchased 2019 Peterbilt 389. I bought the lights to go under the cab and under the sleeper. Could some one tell me if the truck would be pre wired for these lights?
    The last six of the VIN are 629108.
    If it is not pre wired, how and where to I connect these lights?
    My thanks in advance.
    Phillip
  3. tnevin225
    tnevin225 Road Train Member
    1,166
    1,601
    Jan 1, 2014
    Those are not pre-wired as far as I know, I had mine wired into the headlight switch.
    Auctioneer Thanks this.
  4. AModelCat
    154,214
  5. pushbroom
    pushbroom Road Train Member
    1,777
    7,253
    Sep 1, 2012
    Looks like it should be wired from factory. Should have an aux light switch on the RH side of the dash. Wiring leads should be tied up behind air cleaners and under the hood tied up by pass through for the air inlet piping. Diagram attached. If I remember at work tomorrow I'll grab a pic.
    Auctioneer and spsauerland Thank this.
  6. Auctioneer
    72
    38
    May 7, 2010
    Trenton, NC
    Thanks for the information.
    I was able to locate the woring for the sleeper and cab lights. There is a connector for both RH and LH lights. They were in a bundle on the firewall just below the windshield and to the right of the windshield wiper motor.
    Got it all hooked up and working well.
    Thanks Again.
    WyoVac, spsauerland and pushbroom Thank this.
  7. mhlvc
    mhlvc Light Load Member
    111
    43
    May 2, 2020
    You got a picture of where each connector is located by any chance? Trying to hook mine on up
