Twin Stick Transmissions
Discussion in 'Trucks [ Eighteen Wheelers ]' started by MooneyBravo, Jan 23, 2016.
  1. MooneyBravo
    MooneyBravo Heavy Load Member
    840
    1,193
    Feb 20, 2012
    Vermilion, Oh
    After 35 years of banging gears I will take Auto shift every time. I absolutely love the auto shift transmissions available today. I move trucks piggyback out of San Antonio, TX and I drive all new trucks. Many of them come with auto shift transmissions these days and they are very reliable. You can place the switch in auto or manual shift. You know it's funny but you can always spot a new driver belly aching about how automatics are unreliable or getting excited because he has just been assigned a truck with a 13 or 18 speed transmission. Then even though he/she has only 20,000 on board they feel a need to go through every single gear. LMAO I think we all used to be that way.
    While we are on the topic, you know it's funny but you simply can't compare today's trucks to their predecessors. Modern new drivers have no idea how easy they have it with their walk ins and everything else on board these days. They are as different as a DC3 aircraft and a commercial airliner. When I was about 22, one of the first trucks I drove back in '80 or '81 had a duplex or sometimes called a twin stick. You had two shifters; The main and the auxiliary. Today, they are bundled together in the same box, roughly speaking, with the two gearshifts replaced by the shift lever and a hi-lo range selector, roughly equal to today's 9- or 10-speeds. Now, let's see if I can get this right.
    First gear on the main box, low then into high on the auxiliary. That's the easy part. Next, shift the main into second, but before engaging the clutch, you pull the auxiliary out of high, rev the engine, slip it into low and engage the clutch. Now you're in second low. Depending on the load, you might have to do that all the way up through the gears 'till you get to top speed. More likely, you'll cheat and run through a few gears in low before you have to start splitting them. It only gets worse when you get into the 3- and 4-speed auxiliaries; today's 13 and 18 speeds.
    Shift timing had to be impeccable, and good drivers could often skip shift and even split odd gears. If you missed a shift, it would bite you but good. The teeth on the gears were spaced pretty widely apart, so there was a good chance that a partially engaged gear would kick the shifter back. If you were lucky, the meaty part of the palm of your hand took the brunt of it. Drivers have had wrists and fingers broken by the kickback.
    If you happened to miss a split shift, you wound up in what they called double-nothin' -- both transmissions in neutral. That often meant a full stop to get the thing back into gear, though some of the drivers made claims to finessing them back into gear, if they could remember which gear they were in. Personally, I haven't seen this done without a very unhealthy grinding of the gears. You may have seen pictures or heard stories from older drivers about drivers with one arm wrenched through the steering wheel gripping a shifter while the other arm grapples with the other stick. God forbid you happen to hit a pothole at that moment, because the big steering wheel with all its leverage could whip around and easily break an arm.
    Ahh... the good ole days!
  3. Oxbow
    Oxbow Road Train Member
    12,449
    127,848
    Nov 24, 2015
    I learned on a 70 Pete, 318 Detroit with a 5 and a 4. My boss at the time taught me, and he would ride in the passenger seat and slap my hand and cuss as to why I couldn't get it figured out. I finally began to catch on a bit, and he turned me loose to figure the rest out on my own-much easier without him in the truck.
    Then one day a month or so later I rounded the gears in the brownie and hung them up. I was out in the middle of nowhere, and ended up taking the top of the brownie trans off to get it freed up. That is when I learned about the little pins that slide down the sides when you are shifting. After that I learned that a large screw driver was all that was needed to pop it free.
    Those were the days.
    I have driven numerous combinations and transmissions since then; 4x4, 5x3, 10x4, 10, 13, 15, 18, some combination that IH had that had a goofy shift pattern, and a 4x4 air shift spicer. I only drove the spicer a few times, and never did figure out how to use it smoothly.
    I think it was the International that you had to go into 1st, and then farther into 1st to get to reverse. Maybe that's wrong, but it was something really weird - worse than putting an old VW bug into reverse.
  4. slickWillie1980
    slickWillie1980 Medium Load Member
    420
    35,545
    Sep 2, 2015
    Mt Olive, NC
    I would like to give a try on a twin stick just to say I've done it. My dad told horror stories of the B model mack and the triplex tranny. Took some skill I would say
  5. old time
    old time Medium Load Member
    304
    334
    Mar 1, 2012
    First driving job I had was pulling a flat for a guy with some Mack cabovers with triplex trans. It was 1968 and I was a ####y young stud. I can drive that I told him. Um huh. I spent half the day rolling off to the side of the road to start over again. I got pretty good at it after awhile but that was an ornery bugger to drive.
    I bought a Transtar with a 318 and 4x4 trans. Used to run midwest to west coast. That gutless 318 had me shifting so much my arms were ready to break. I remember I gave a guy a ride one day. He had a 335 cummins in his truck and he laughed at me. He said "no wonder you have arms like tree trunks" You shift more in an hour than I do in a week
    Bean Jr. Thanks this.
  6. Cat sdp
    Cat sdp . .
    20,819
    71,604
    Apr 8, 2012
    Orion's Belt
    This guy is great.
    bubbanbrenda, Bean Jr., Oxbow and 5 others Thank this.
  7. wore out
    wore out Numbered Classic
    15,319
    184,959
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    One of my favorite you tube vids right there
    MJ1657 Thanks this.
  8. slickWillie1980
    420
    35,545
    Sep 2, 2015
    Mt Olive, NC
    he makes that look so easy lol
  9. coffee mug
    coffee mug Light Load Member
    112
    50
    Jan 22, 2016
    stick shifts are good for getting unstuck in the snow
  10. MooneyBravo
    840
    1,193
    Feb 20, 2012
    Vermilion, Oh
    A screaming Detroit. Operating range was up to about 2600 if I remember correctly.
    Oxbow Thanks this.
  11. MooneyBravo
    840
    1,193
    Feb 20, 2012
    Vermilion, Oh
    LOL I remember the 16 speed Spicer. If I remember correctly, I t was an H pattern and you had a selector button on the shifter with 4 positions. Right?
    Update: I found this video.
    Oxbow Thanks this.
