do i have to have a twic card to be hired by companies? i was told i do but ive also been told that the companies will help you obtain them. so which is it? im confused.
twic card
Discussion in 'Questions From New Drivers' started by bubbaray30, Jan 16, 2014.
Some require it, others don't. It does make you more attractive to certain companies. If you're dealing with ports and/or military bases you will need it.
I've never had one and only been asked about it three times. Once at an aluminum foundry in owensboro ky. All they said was I should have one and that's the last I heard about it. Twice at the port on Baltimore, md. I had to be "escorted". That consists of one guy in a security truck parked in eyesight just in case I decide to run off with 46k lbs of aluminum.
Have never been asked for a twic card at a military base. A couple of years ago I ran 4-5 bases a week and was not asked even once. NOB Norfolk, Ft Knox, Ft Campbell, Pope AFB, Wright Patterson AFB, NAS Corpus Christie just to start -
Not all companies require TWIC; most hazmat tanker companies do. You must get the TWIC on your own at a TWIC office. Don't know if any companies front the money for TWIC or not. I think they closed the TWIC office in Old Hickory where I got mine. You may have to go to Chattanooga.
Depends on company, most will hire without it, but if u pickup at ports it will save moeny and time not needing an escort.
Not unless they require it. TWIC cards are only applicable if you're going into a port facility where there's water nearby. I haul hazmat tanker loads (chemicals) so in my case yes, I have a TWIC but even then, many companies don't ask for them. I've read that they're going to ask for proof of nationality soon in many facilities, or resident alien proof. This red tape BS never ends.
is it vert expensive to obtain it?
is it very expensive to get it?
