Turnpike double or LCV
Discussion in 'Ask An Owner Operator' started by Batmanjatt, Mar 26, 2023.
  1. Batmanjatt
    Batmanjatt Bobtail Member
    5
    Jul 10, 2022
    Edmonton
    Hello fellow truckers
    I just want to know do I need a heavy spec truck to pull 2 53ft trailers(turnpike double or LCV)?
    Do I need super 40, 46k differentials or regular 40 work too?
  3. ducnut
    ducnut Road Train Member
    2,440
    7,257
    Dec 31, 2010
    SPI
    My previous employer didn’t spec anything different. The drivers ran Gary, IN, to somewhere out east. I can’t remember the destination.
    Siinman Thanks this.
  4. abyliks
    abyliks Road Train Member
    3,750
    8,700
    May 2, 2010
    ludlow MA
    It’s all paved highway, I would think even 38k rears would work fine,
  5. Siinman
    Siinman Road Train Member
    5,161
    12,948
    Mar 5, 2017
    Kansas City, MO.
    I would guess as long as you are on legal weight on axles it wont matter. But I have never pulled doubles so I am just guessing.
  6. North Pole Nightmare
    North Pole Nightmare Heavy Load Member
    816
    1,594
    Dec 15, 2021
    You don't have to go heavy duty but it's a lot better,with big hp also.
  7. FLHT
    FLHT Road Train Member
    1,330
    2,262
    Aug 2, 2014
    Some states require having x amount of horse power when pulling LCV..
  8. Magoo1968
    Magoo1968 Road Train Member
    2,017
    5,395
    Mar 18, 2021
    St Malo mb
    In Canada lcv trucks need a bigger air supply and compressor.. I suspect USA has the same air requirements.
    Albertaflatbed and Rideandrepair Thank this.
  9. Rideandrepair
    17,223
    55,904
    Aug 8, 2015
    That’s a good point. Bendix has a table with illustrations explaining the suggested sizes for different combinations. I wonder how many Trucks pulling 2 53’s actually have a larger compressor. I considered a tuflo 750 to replace my original 550. Would be nice, quicker recovery, especially for running air tools. Decided against it because of extra HP needed to operate. Possibly costing me fuel economy.
    Magoo1968 Thanks this.
  10. uncleal13
    uncleal13 Road Train Member
    3,797
    6,293
    Apr 9, 2009
    Humboldt, Sk
    Most 40’s can handle the added pulling weight on “turnpike highways “ no more than 3.5% average grade. According to the specs.
    I would venture if your rears have the light weight housings ( stamped 9.5 mm) then they may not stand up to extended use.
    11 mm housing would be better.
    12.7 mm are used for the 46,000 lbs axles. We used those pulling super b trains, but we went off road with them into farmers fields and drove lots of gravel roads.
    Albertaflatbed Thanks this.
