Turning up a 903
Discussion in 'Ask An Owner Operator' started by barroll, Jul 10, 2012.
  1. barroll
    barroll Road Train Member
    1,096
    544
    Nov 23, 2010
    Southwest Michigan
    Putting around with the door plate rating of 290HP is not working out. When I bought the truck, it was listed as a "350 cummins", so don't even get started on the "well why did you buy such a weak engine" bit. Running up to Pueblo, CO at around 7,600ft was no pleasure holding onto 1st gear for dear life at about 4mph and watching the engine bog 300rpm every few seconds between 1100 and 1500rpm. Getting stuck at whatever speed I was going up anything that is slightly steeper than flat is no treat either. I've also read here and elsewhere that these engines can see a bit of an economy gain with a bit more power up the hills, which would be welcome, since I do about 5.5mpg on flat ground.
    The engine was rebuilt less than 25,000 miles ago, so my only concern with turning it up is the driveline. The transmission has around 250,000 miles on it, and the pumpkins aren't stock (door plate is 4.56, and differential tags read 4.44 after I scraped off 2 layers of paint), but I don't know how much life is left in them. I've got a misfiring cylinder, and the turbo is running in the single digits, so I need to get that sorted out first, but I'd like to sort out my options in case I don't find the power I need getting those two fixed.
    I've talked to a few former 903 owners from back in the day (all wrecker operators now, coincidentally) and they all had different methods of getting more power out of the engine.
    1) Twin turbo setup @ 850hp
    He didn't recall the specifics of the upgrades, but he did note that this power rating caused more trouble than its worth, and I'm really not interested in that kind of power, since I won't be doing over 80k gross.
    2) Drilled out bearing @ 390hp
    This was a roadside story about how he drilled out a ball bearing where the throttle rod enters the fuel pump. I wasn't entirely clear on the details, but he did note that this modification made the engine competitive with the other big V8s of the day. Kind of iffy on how sound this modification is.
    3) Shimmed and buttoned/springs
    Heard this one most commonly, running anywhere from 400hp-600hp. Simple fuel pump work for simple gains, backed up by the field service manual I have from the U.S. army on this engine.
    I'd like to see 350-400hp out of this engine, and spare the bottom end the strain of a bigger gain. I'm not trying to drag race a semi, and I'm not big on passing everyone in the right lane, but I don't think pushing the engine to its mechanical limits all day every day is a good way to run it. I'd also like to give my 4 way flasher relay a break a few times a day, since I've overheated it more than once.
    Any experience/other suggested methods for achieving this?
  3. jbatmick
    jbatmick Road Train Member
    2,195
    2,458
    Dec 1, 2009
    hastings, Fl
    We used to run a 9 nothing 3 with a single turbo, and it had a reputation as a fast truck, back 35 years ago.Work with what you have, sounds like your turbo is the culprit. How many rpm's are you turning ?
  4. bender
    bender Road Train Member
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    You'll never make rated boost with a misfiring cylinder so you need to address that first. Although a new turbo can really spice up overall performance, base engine health would come first. The fuel mods you choose will be limited by your injectors so if you have a bad one now would be the time to go to higher flowing injectors along with a combination of #1 and #2 plus an AFC adjustment. If you haven't done so already, I would replace the fuel lines.
    barroll Thanks this.
  5. 1958Pete
    1958Pete Light Load Member
    171
    64
    Sep 12, 2011
    Jonesville, Louisiana
    Other than addressing the issues that have already been discussed, you should go over to the "Diesel Garage" site and ask this same question about bumping up your 903. There are several cummins folks over there that can give you some good ideas and suggestions.
    http://www.thedieselgarage.com/forums/forumdisplay.php?f=10
    You should see some fuel mileage and power increase, once you address the turbo and missing issues, if you're already getting 5.5 mpg in the flatlands.
    Good luck!
  6. barroll
    1,096
    544
    Nov 23, 2010
    Southwest Michigan
    If it isn't being temperamental and sticking between 1800 and 2000 (stays between 1900 and 2100 if I kick it down to direct) I'll usually run it around 2150, which is somewhere around 66mph (speedometer cable binds), but I'll run it all the way up to 2500rpm up and down hills, and that just falls of going up most hills, and it'll start to hold around 1700-1900rpm if I'm in the right climbing gear.
  7. bender
    2,105
    1,352
    Jul 20, 2010
    Don't Kid Yourself
    Correction, your #2 and #3, I wouldn't do #1.
  8. barroll
    1,096
    544
    Nov 23, 2010
    Southwest Michigan
    I'm working on the misfiring cylinder. Been talking to some boat guys that run 903's, and they said plugged air filter elements can cause misfire in these engines, and the date on the one I've got is 7/08. Got a new filter ordered and waiting for me back in bloomington, so I'll give that a shot when I can get to it.
    Beyond that, kenworth and cummins have both told me they only have one type of injector for this engine. Would I have to go aftermarket for a higher flow?
    In addition, I have two spare injectors, but haven't found anyone that will rebuild them, or even test them. I've rebuilt injectors before, but they were less than half the size of these ones. Anyone have a resource for rebuilding diesel injectors? Any special tools I need to worry about? Any part suppliers if I find something wrong going through it?
    I'll definitely get the fuel lines swapped when I get the misfire looked at again. Nothing came up on a pressure test, but I've had a hell of a time priming the filter, so I think something might be up with them.
  9. MNdriver
    MNdriver Road Train Member
    7,985
    4,371
    Feb 24, 2012
    Things I learned on the 903.
    Set the valves/injectors a little on the loose end of the spec. When it warms up, it tightens up and runs better.
    You have to stay on top of the rack and keep it adjusted properly. A well tuned 903 did wonders in the bradley's we worked on.
    But you also had to pull the pack out of an armored vehicle to do it. Makes for an all day task so it wasn't done unless it really sucked.
    http://www.dkdieselinjection.com/index.html
    Check out those guys for rebuilding your injectors. The guy I used to use is no longer in business and I have to find another one. They are the ones around here that keep getting recommended.
    1958Pete and barroll Thank this.
  10. Kittyfoot
    Kittyfoot Crusty Ancient
    2,092
    3,056
    Sep 21, 2009
    Sorrento, Louisiana
    Check out a Marine Diesel shop. Alot of these older diesels are still running in fishing boats, etc.
    Where do you think they came up with the nickname "Boat Anchor" for the 903 anyways.:biggrin_2559:
  11. Autocar
    Autocar Road Train Member
    3,167
    2,358
    Apr 28, 2012
    The Hot Rod Shop Oxford, AL
    V-8 motors were not designed to run at the same rpm as the straight 6s. I ran naturally aspirated V903s back in the 70s and our rpm range was between 2000 and 3000 rpm, although we ran them regularly at 3200 rpm. Thomas Produce, Greensboro NC, had a bunch of them, with turbos, and tried running them below 2000 rpm to save fuel, which did hurt their performance.
