Help me understand turning radius. I wanna know if higher number radius is better than lower number or is it opposite? How does someone determjne whats a good radius vs bad one.
turning radius... whats better higher number turning radius or lower number?
Discussion in 'Experienced Truckers' Advice' started by dirtjersey, Oct 15, 2012.
Page 1 of 4
The lower the number (number = feet), the tighter the truck will turn. Which is better depends on the type of work you are doing. Longer wheelbase trucks (larger turning radius) usually ride much smoother than short wheelbase (tighter turning radius) trucks.
dirtjersey Thanks this. -
think of it this way a tire the inside is a shorter distance tighter radius the outside is a longer distance longer radius
I dont understand that analogy can you explain it. Thanks -
go out and look at a tire I am sure you will figure it out.
Nope dont get it. Dunno what you mean between longer and shorter.
Imagine you're in your small car and you can routinely make a U-turn in a street without hitting the curb. You get in a another car that is either longer and/or doesn't turn as "tight" ... you try the same u-turn from the same spot, and HIT the curb.
In trucking and backing, a "quicker" turn can make a difficult back seem relatively easy as opposed to having to back it with truck with a longer wheel base (slower to turn)
Mostly the turn radius is affected by the wheel base (truck length) (center of steer axle to center of drive tandems), but the engineering of the steering system(s) also affects this number.dirtjersey Thanks this. -
O ok got it. Thanks
And a wheel base is the distance between the two tires that are on the same axle. The inside tire and the outside tire. So if the 2 dual rears closer together then its a tighter turn radius. If the dual rears are further seperated then its wider turn radius. Is that cprrect?
Page 1 of 4
