Good afternoon everyone, I know there are a few posts about this but what I've read hasn't gotten me any closer to solving this issue. I have a 1993 Freightliner fld120 the turn signals and emergency flashers are not working they will light up when I engage them but no flashing. I have replaced the turn signal switch (lever assembly) new flasher relay and circuit breaker checked for power where it should be 12.4 volts at all points.All other lights work as they should. ANY HELP IS GREATLY APPRECIATED THANKS IN ADVANCE...
Turn signals and emergency flashers not working
Discussion in 'Trucks [ Eighteen Wheelers ]' started by Westbatm74, Mar 23, 2019.
Would also like to add that all lights are LED and the flasher relay is compatible, also I did take the square black cover off relay and moved the arm inside back and forth working it manually and it made no difference. Also I do have the Original wiring diagram that came with the truck and will post it for anyone who may need it.
They work off the inside of speedo panel and conn. have been lost from broken conn. inside it?
I guess what I'm asking is where would the connection be broken at ? The speedometer itself or do they share some of the same wiring?
Also someone said it could be in the light bar where the turn signal indicators are
Inside the dash panel you will find a soder conn. that is broken using a heat sink you can fix it with the right type of soder and a iron
Did you change the flasher it's self ,also some trucks have two 1 turn signal 1 emergency flash? Some located in the fuse box, Many behind the dashboard ?good luck!
In the old CO. trucks a driver could tap the dash panel with fist and sig. would blink for a while??
BoxCarKidd Thanks this. -
Ok I'm going to look for that broken connection , Thanks again for your help.
